I'd be interested perhaps. Not sure on the value though.
I have a question:
Would there be any interest in a scanner modding service to install a GPS in scanners for those who are not highly skilled with a soldering iron?
If so, any thoughts on the value of such a service?
I would be very interested in an internal GPS installation service, and would likely pay anything within reason to someone who could do it quickly and cleanly.
It doesn't attach directly to the scanner circuit boards. The pads for the power and serial data connections aren't even on the same circuit boards. There's also a second module needed to convert from TTL to RS-232 signal format. There's space in the rear of the scanner case where the GPS module and converter chip can be installed such that the GPS patch antenna is not obstructed by the circuit boards and shielding inside the scanner. Wires need to be run from that location to the pads on the circuit boards for power, ground and serial data.
And where on the PC Board do you propose to install it?
The first one is the worst of all worlds--small less sensitive antenna, extra-large circuit board, and twice as expensive as elsewhere.
The second one has the same antenna, but is small enough to install without making a cutout in the case for the antenna. It is available on ebay for about half the price.
All of the commonly-available GPS modules have TTL output, and require a TTL-to-RS232 converter between the GPS and the scanner, such as the MAX3232 module. There are some wiring tricks needed to prevent the MAX3232 from drawing excessive power and frying itself. Read my previous posts in this thread for details.
Post #93 is the key.
