I think im going to pass on a true SDR i might look into buying a tentec rx320
Before you pass on a "true SDR" remember that the SoftADD66 was just about as low end as you can get. The front end was horrid, and the perfromance was limited by your sound card. There is a reason it was as cheap as it was. It absolutely should not be confused with, just as an example at the low cost end, an RFSpace SDR-IQ, there is absolutely no comparison. Rather like saying cars suck because the 1919 Model T is not quite as good as the 2010 Ford Fusion.
SDRs like the SoftADD66 are best used looking at the IF of a traditional radio, so that they have the traditional radios front end to tweak up the signals, not used as a stand alone rig themselves.
With an SDR like the SDR-IQ, SDR-14, WinRadio Excalibur, Perseus, or QS-1R the performance (dynamic range, filtering, SNR, etc) is not limited by your sound card. Every one of those rigs can bring the data (IQ demodulated RF) straight into your PC without being handled by, and limited/distorted by, the sound card first. The sound card is only used to reproduce the sound. For one of my SDR equipped PCs I use a Soundblaster 16 PCI, and it performs as well as the Sooundblaster PCI 512 equipped PC for SDR use.
Because the RX-320D has no built in control panel and is just a traditional superhet that must be computer controlled (but is not an SDR) there is no advantage to be had selecting it over an SDR like the SDR-IQ.
T!
Mohave Desert, California, USA
