- Joined
- Feb 12, 2014
- Messages
- 36
- Reaction score
- 8
Ok now I understand what you are saying. I will get that changed. Do you think that could be causing the issue I have with it not picking up on transmission right away with coverage disabled?
Actually it looks like you have the system set to Coverage = Disabled, since all of those options are grayed out. Please see my warning a few posts back. You need to set it back to SmartZone in order to prevent the radio from attempting to register/affiliate.View attachment 143825
Does this look correct for the trunking personalities for Somerset County for the UHF portion of the trunking system and the trunking personality? Making sure this trunking personality is set to perferred for the UHF trunk site
Okay thanks for the update. You are right I did notice that certain areas are greyed out now since put the system from SmartZone to Disabled.Actually it looks like you have the system set to Coverage = Disabled, since all of those options are grayed out. Please see my warning a few posts back. You need to set it back to SmartZone in order to prevent the radio from attempting to register/affiliate.
Once you do that, then no, those are not the correct settings for Preferred Sites. The settings I recommended are detailed in my last post, however normally they have no effect on NAS. Doesn't hurt to try, but probably won't make any difference.
Where are you monitoring this system from? Inside the county?Okay thanks for the update. You are right I did notice that certain areas are greyed out now since put the system from SmartZone to Disabled.
Working from where, and what model APX?But its working for now perfectly.
Do what?No. Go back and read my earlier reply. You must set each system's Site ID to the actual Site # for each cell.
You have to make sure this box is UN CHECKED if you are in disabled mode. When this box is un checked the system will not validate the NAC again the System ID.Actually, I'm going to suggest that you NOT follow my previous advice. Something in the back of my head is telling me that if you set an APX to Disabled coverage on a P25 system, even in NAS mode, it WILL try to register/affiliate. Yes, even when parked on a conventional channel instead of a trunked talkgroup.
