ID2003
Space Suttle Discovery is scheduled to blast off to the International Space Station at 6:21 a.m. April 5, from Kennedy Space Center. This is the 131st shuttle mission, with only 3 left after this flight.
Don't forget! If you're within those circles shown on the visibility map in the previous post, you should be able to copy some of the shuttle transmissions on 259.7 Mhz AM. I know I've copied quite a bit in the past from here in Eastern NC with simple equipment.
Off by an hour... It's 6:21am EDT (most of the US uses Daylight Saving Time.)Space Shuttle Discovery STS-131 is now in the process of fueling up it's external tanks. It is scheduled for liftoff at 6:21 AM EST.
