split rock
svw
palmerton pa
does anybody know the freq and pl for split rock in lake harmony area,is it repeated.
thanks
scott
captclint
Mountaintop, PA
This is from the FCC DB, so it is not confirmed, and is not a repeater. It's only 20W, so you may not hear it if you are more than 20 miles.
WNDZ720
158.4600
I should point out that the FCC Lon/Lat is NOT correct(40-02-55.4 N, 075-35-52.7 W). It should be closer to 41-3.96, 75-37
svw
palmerton pa
If i saw the anntennas right i belive they are working off uhf,no body seems to beable to locate those frequiences. They will be building a indoor water aprk in the next year,so maybe something will pop up then,the security people had the radios and we acn hear them on the ambulance radios on uhf,will check there..
scott
