Splitter for more than one scanner
sonm10
Central MN Monitor
Sauk Centre, Minnesota
I always used a simple cable TV. spliter.
Maybe install a different connector and suffer a bit of signal loss, but I never saw a big loss. Give it a shot.
DW
So. Cal
Myself and several other use the home brew method - preamp before a TV splitter. The splitter usually has quite a bite of loss, which the preamp makes up for.
My setup uses a PGA 103 lna with 20db gain @ antenna. 8 way splitter ~11db loss.
Others also use the electroline which includes the LNA in the splitter.
Bonkk083
Union, SC
MCA204M, MCA204MIL or MCA202M below
Frequency Range: 25 MHz to 1 GHz 4-Ports
Nominal Impedance: 50 ohm
Port-To-Port isolation (min): 22 dB
Return Loss (all ports): > 20 dB
P1dB = 17 dBm (output) 3OIP = 32 dBm (output
Coupler Gain/Loss: +2 dB to -1 dB (max) over frequency range
RF Connectors: BNC (standard)
Mechanical: 4.375 X 2.375 X 1.250 inches (L.W.H)
Case: Die cast Aluminum, Black powder coating (standard)
DC Power Connector: 2.1/5.5mm coaxial (standard)
DC ower Requirements: +12VDC (nominal) @ 85 mA
How do you read this for as gain or loss
Roughly speaking, each output port will have between +2dB of gain to -1dB loss. That'll depend on frequency, probably -1dB (a bit of loss) on the higher frequencies or lower frequencies where you are not likely to be listening. 2dB of gain on the common LMR bands is pretty good. You usually don't want more gain than you need.
That's better than an unamplified splitter that would probably have 3.5dB of loss on the scanner port side.
Bonkk083
Union, SC
Would that be okay to use
Purchase, that's what my electronics store has
If they have it, and they can install appropriate connectors on the cable, then it would be fine. If you need to use adapters to make it work, I'd pass.
You don't want to add unnecessary adapters to make things work. They are a failure point and add loss.
A short run of RG-59 would work.
Find another place that will sell you either RG-58 or RG-6 with the right connectors on it.
Bonkk083
Union, SC
I think it comes with the connecters and it's 3 feet
Well, the ones I linked to above are $10.95 and uses RG-400, which is much better cable than RG-59.
While a short run of cable isn't going to make a huge difference, RG-59 is pretty much bottom of the barrel.
Edelweiss
Author of: Scanning the UK Airbands with the Beast
England
U don't need a multicoupler, a good quality splitter will do fine, especially for only two scanners. I make some x2 and x4 in small series at times so contact me if you're seriously interested. Am using passive 4-ways for years and don't miss anything, really. To use a multicoupler well you need to make a bit of effort and pay a lot as well.
Ubbe
Stockholm, Sweden
OP needed splitters without any loss. When you split to two it will be a 3dB loss plus the internal loss in the splitter 0,5dB-1dB and if using a 4 port it will be less than 25% of the signal left for the receiver. It's fine to use passive splitters if everything you listen to have a high signal strength. Usually the amplifiers used for splitters gives a little gain out the splitter and have lower internal noise figure than the scanner so it will actually receive better using amp+splitter than the "naked" coax from the antenna connected directly to a single scanner.
/Ubbe
