- Joined
- Nov 27, 2006
- Messages
- 1,981
- Reaction score
- 38
I have a dual DVR system in my home, the second TV is so far from the first that the little UHF antenna doesn't work well. I had saw one before with a Diplexer hooked to the tv2 out and the antenna out and had it run into one cable then the antenna on the other side and hooked into a regular splitter on the other end and extended the antenna, However when I tried that with the diplexer I ordered that says TV VHF on one side and SAT on the other, The antenna wouldn't work or it would and the picture was scrambled. Do I need another diplexer on the other end to unscramble it and make it work or do I just need a DUAL VHF in instead of SAT VHF...Anyone experienced with this, Any Suggestions, Ideas, Fixes?
Thanks.
Brian
Thanks.
Brian
