Splitting an antenna
jazzboypro
Laval
Hello all,
I hope i am in the proper forum for this question. I currently have a single antenna (GP-3). This antenna is for the 144/432 bands. I want to use this antenna with an Icom IC-9700. This transceiver as 1 connector for 144 and another connector for 432. So i need a device that will allow me to connect a single antenna on 2 different connectors on the same radio.
I was looking at antenna switches but they appear to be used to connect multiple antennas to a single connector on a transceiver.
What would you recommend to accomplish my scenario ?
Many thanks
73
K4EET
Chaplain
Severn, Maryland, USA
Are you a ham? Will you be transmitting with this transceiver or just receiving?
<edit> I ask because it makes a BIG difference in how you might do this connection...
PrivatelyJeff
Has more money than sense
Kings County, CA
Hello all,
Many thanks
73
You want a diplexer
jazzboypro
Laval
My bad, i should have mention it. Yes i am (VA2FCS) and yes i will transmit.
PrivatelyJeff
Kings County, CA
look up diplexers. It’s a special type of splitter/combines that splits/combines by frequency. Connect each leg of the diplexer to the appropriate connector on the radio and the antenna to the feed connection on it.
K4EET
Chaplain
I believe you should be looking at a Comet Antennas CFX-4310C or equivalent since you actually have three connectors on an Icom IC-9700. That way you are "future-proof" and you have all of your ports terminated although your antenna might not have a 1.2 GHz band. I am not familiar with a GP-3 antenna.
<edit> If you cannot find a Canadian supplier of that part, GigaParts in the States has the part. You will also have to mate the N connector on the Icom's 440 MHz port to the UHF connector on the Comet. I think I have all of that right now. LOL! (enough edits!) Not sure what is on the antenna. Final note is that this all assumes you do not have an outboard amplifier. Watch the specs of the Comet.
iMONITOR
Silent Key
S.E. Michigan
Another option:
MX3000N Diamond Triplexer
Specifications:
  • Port: LPF/BPF/HPF
  • Frequency (MHz): 1.6-160/350-500/850-1300
  • CW W: 400/200/100
  • PEP W: 800/400/200
  • Loss dB: .2/.3/.4/
  • Isol dB: 55/55/55
  • Mix Connector: N-Jack (F)
  • Port connector: PL-259 & 12" 5D cable/N-Male & 12" 5D cable/N-Male & 12" 5D cable
K4EET
Chaplain
Thanks for chiming in @iMONITOR. I made a real mess on my response. I took a simple device and made a complex response and got myself all tongue-twisted! I should have formatted my response like your response. It would have been a lot easier to decipher. My bad. Sorry @jazzboypro
iMONITOR
Silent Key
S.E. Michigan
Nothing wrong with your post K4EET. I value your post as they reflect years of experience and ideas! I only chimed in with an alternative in case he couldn't find the Comet device.
You want to talk about making a mess of a post, how many have I messed up. Buy hey we try to help people when we can and that's what it's all about. Usually people figure out what we meant to say. Sometimes I see what I posted a couple of days and I'm like what was I thinking? o_O
jazzboypro
Laval
Your answer was quite clear actually. Thanks for pointing me in the right direction and for suggesting a vendor.
73
Sylvain
jazzboypro
Laval
Another option:
Specifications:
  • Port: LPF/BPF/HPF
  • CW W: 400/200/100
  • Isol dB: 55/55/55
Thanks iMONITOR, this looks like what need. The one suggested by K4EET is pretty good also, but the Diamond comes with the cables already there so i will go for that one.
Many thanks.
73
Sylvain
sallen07
Rochester, NY
I would suggest you look at either the Comet CF-416B or CF-416C. They both come with an N connector for UHF and PL-259 for VHF, which will connect to your IC-9700 without needing an adapter. The Diamond one has N connectors for both UHF and VHF, and you really don't need a triplexer. The B has an SO-239 for the antenna connection and the C has a female N connector.
If you are planning to do 1200 MHz work then I'd consider the CF-416W. You'll need an adapter if your antenna lead has a SO-239.
jazzboypro
Laval
Thanks for your suggestion but according to the specs for the MX-3000N the connectors are Ok and it matches the connectors in the back of my IC-9700
Manufacturer's Part Number:MX3000N
Part Type:Duplexers and Triplexers
Product Line:Diamond Antenna Triplexers
DXE Part Number:DMN-MX3000N
Low Pass Frequency Coverage:1.6-160 MHz
Mid Pass Frequency Coverage:350-500 MHz
High Pass Frequency Coverage:850-1300 MHz
Low Pass Loss:0.2 dB
Mid Pass Loss:0.3 dB
High Pass Loss:0.4 dB
Low Pass PEP:800 watts
Mid Pass PEP:400 watts
High Pass PEP:200 watts
Isolation:55 dB
Mix Connector:Type N, female
Low Pass Port Connector Type:UHF male, PL-259
Mid Pass Port Connector Type:Type N, male
High Pass Port Connector Type:Type N, male
AK9R
Central Indiana
Since your IC-9700 has *two* antenna connectors, one for UHF and one for VHF?
It has three. The IC-9700 works on 2m (UHF connector), 70cm (N), and 23cm (N).
iMONITOR
Silent Key
S.E. Michigan
My bad. I saw "N" and assumed they were all N. We know what they say about assuming! :)
But you still don't need a triplexer, right? Since your IC-9700 has *two* antenna connectors, one for UHF and one for VHF?
It has three. One SO-239 and two Type N connectors:
sallen07
Rochester, NY
LOL. OK I'm just going to go crawl under a rock for the rest of today. :rolleyes:
I started looking at the specs and saw "SO-259 for VHF, N for UHF" and stopped reading. Doh!
"Never Mind"
iMONITOR
Silent Key
S.E. Michigan
I started looking at the specs and saw "SO-259 for UHF, N for VHF" and stopped reading. Doh!
"Never Mind"
Been there, done that! Time for coffee...:coffee::)
