Two BCD996P2 scanners fed by one antenna using a BNC “T” as the splitter. The antenna uses a “N” connector and the LMR400 coax has “N” connectors on both ends. An adapter was added (N to BNC) to feed the “T” connector and two runs of LMR400 feed the scanners.
While receiving a trunked P25 system one scanner hears this system but the other does not… it did when it was first added but now it doesn’t. Only one of the scanners if adversely affected-it’s always the same scanner. Both scanners are programmed identical-cloned. Any ideas why this happened?
It should be noted that while both scanners are programmed identically (cloned), and a simple extension speaker should be all that’s needed to hear the same in two different locations, it was decided a second scanner should be used in order to allow for lockouts for the two respective rooms being served. One room is a meeting room and the other is the dispatch center in a firehouse. It gives either location the ability to “Avoid” certain agencies, lower volumes, etc.
