SSTV Question
WB2UZR
Melbourne, Florida
Sstv
A lot of folks use MMSSTV, there are others I imagine:
http://mmhamsoft.amateur-radio.ca/mmsstv/
Other than that, just a scanner or VHF rig, helps to have an outside antenna, but not mandatory.
Scott/WB2UZR
PS The ISS has gone over to Packet, you can check ISS Fanclub or AMSAT sites for updates!
Wahoos4Life
Rixeyville Va
yea i had downloaded Mmsstv and ben playing around with it
So well my Radio shack pro 2054 work for this?
If so i just need to get the audio cable to connect it to my computer?
i also put my antena up on the roof
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes the 2054 will work fine. The trick is to get a clean connection from the scanner to the soundcard without getting a lot of junk from the PC in the way. Short and sweet, using shielded audio cable, is the way to go.
Getting the soundcard to work does take some doing, however. This wiki article will give you some hints and how to get around some common issues (anything in blue or underlined is a link)
http://wiki.radioreference.com/index.php/Connecting_Radios_to_Soundcards
73 Mike
Wahoos4Life
Rixeyville Va
73 Mike
Cool, im using a Notebook so im just going to plug the scanner into the mic port of my notebook
What is the proper frequeny that the ISS uses for this?
WB2UZR
Melbourne, Florida
They have been on 145.800, but they have gone over to 9600 baud packet on 145.825. There hasn't been any SSTV for a few days now.
Scott/WB2UZR
Wahoos4Life
Rixeyville Va
Scott/WB2UZR
How do you know when they are sending them out and changing freq's?
sorry for all the questions
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The freq is 145.8 for voice/sstv, 145.825 for packet.
Read the links in the wiki article I supplied in message 3 for more. There are several ISS related links there
73 Mike
WB2UZR
Melbourne, Florida
One good way to keep up with what's going on is the ISS fanclub site at http://www.issfanclub.com/
Over on the right side is a status listing that's usually pretty up to date, it's sent in by listeners around the world. Also check http://ariss-sstv.blogspot.com/ There is a list of links there that can be helpful down on the right side of the page, especially the SAREX reflector.
Scott/WB2UZR
