ST-2 Antenna
Blackink
Central Vermont
All I can tell you is when I installed an ST-2 antenna about 40' in the air and connected it to my BCT15X, the difference I noticed was night and day from using the stock antenna that came with the BCT15X scanner.
I was picking up frequencies 10-20 miles out with the stock antenna at maybe 3-4 bars signal strength, higher if closer.
After I installed the ST-2 antenna, I was picking up frequencies 50-75 miles away at 4-5 bars signal strength.
As far as whether turning the ST-2 antenna helped in picking up better or not, I live in a mountainous region so I just "pointed' it towards the area with the least amount of mountains. haven't touched it since and I'm quite happy with the performance. The ST-2 has been up for about one year now with no problems.
It is quite tall/large though.....
I haven't used a discone....
EDIT: I even connected my new BC125AT handheld to the ST-2 antenna and it performed great.....
jack103
Tewksbury MA
Steve if you get any antenna up 40 ft your going to get great results then the supplied back of the set antenna.
