St Louis FD Reprogramming
scanman1958
St. Louis
All morning long St Louis FD units have been going by fire alarm headquarters to have their radios reprogrammed. Battalion Chiefs also. Does anyone have an idea as to what new TG's they might be getting?
Starcom21
IL /MO/Global DB Adm!n
They've been testing on 10232 the last week, I think it may be EMS. Abbott was heard on it the other day, on the wrong channel, per dispatch.
Best thing to do is open up your scanner to hear all talkgroups and help us all figure it out.
Also, hearing testing this morning on the 8CALL/8TAC repeaters 851.0125 (CSQ for some reason) and 851.5125 156.7 PL
scanman1958
St. Louis
I know, and it's pretty obvious, that Abbott is helping the city with EMS coverage. Usually 4 to 5 trucks. Medic One has 1 to 2 in the mix. Maybe they will get their own channel, who knows. I already have my scanners set up for SEARCH mode. I'll let you know if I hear something.
Starcom21
I heard a high pitched tone on 10232 earlier, that was it.
EMS and Fire Dispatch appear to be normal right now.
Yes, they contact abbott to sit at fire stations instead of one of their Medic units. It is possible they can call Abbott directly for extra units, if available, but those units will not have any city radios. (Last I knew)
AC0RV
Park Hills, MO
I was at MO Bapt in St Louis. and heard Abbot as well on that talk group as well.
scanman1958
St. Louis
The Abbott and Medic One units assigned to the city have handheld radios provided by the city and are dispatched directly by SLFD EMS dispatcher on TG 10201. Their on air radio number relates to the engine house they are assigned to.
Starcom21
OK. the tone I keep hearing on 10232 is just my darn unication pager, disregard that. It just seems now that twice in the last week, that Abbott had their radio on the new channel, and dispatch both times told them they were on the wrong channel.
So, it's possible the updates have been made to the portables and that is still a future use channel.
I don't remember that the Abbott number, like 106, etc, relating to the station (it very well may), but I know that is what is used in the AMR/Abbott CAD system they use with their "LOGIS" handheld devices. Abbott St Louis itself does not use any radio system (normally) and some units only have hospital channels. While the EMS unit numbers on air may be the same every day, the actual ambulance used every day could be a different vehcile (3 digit # or 5 digit VIN on the vehicle)
(Note: I worked dispatch, for the company for 2 years)
WingnutStl
I do NOT have any firsthand knowledge of this, but it could be that they are loading encryption keys into the radios. That would not necessarily mean they would go encrypted, but it could give the SLFD access to encrypted talkgroups that they don't currently have access to. Just a thought
AB5ID
Lee's Summit, MO (Kansas City)
The Kansas City Fire Department similarly called in units to the IT department, a few at a time. Over the radio, they mentioned it was to update their passwords. This action was taken after Jackson County, where our county is located, was hit with ransomware. I was also curious if they were setting the radios for encryption.
Starcom21
I heard another Abbott unit this morning on 10231, and dispatch said you are on "Fire Main", switch to EMS Dispatch. This is also a new talkgroup, but not sure if it is actually going to be "Fire Main"
llzel
St Louis, MO
I'm thinking that maybe they will add a Fire Main and maybe an EMS main rather than continue using dispatch as both. I'll keep watching here to see what I need to program into my Unication
PVPD730
Several months ago, KCFD radios were reprogrammed and keyloaded with encryption keys, however, they don't have any plans to go fully encrypted on the A-1 primary and Ops talkgroups. According to the MARRS Management Committe at MARC, they added the encryption capability so personnel can use the encrypted REG COM talkgroups and for interoperability purposes (i.e. if they run a call with Gladstone or CJC Fire both of which are encrypted).
Starcom21
I still keep hearing occasional transmissions on 10231 and 10232.
Starcom21
Has anyone else worked on any of this? (sorry, forgot to remove duplicates)
Radio IDCommentTG
204104Police D4 Dispatcher 104
204107Police D4 Dispatcher 107
204113EMS Dispatcher 113
204114EMS Dispatcher 114
207126SLC Gateway unit
207127SLC Gateway
207132at gate 10SLC Gateway
207132SLC Gateway unit
207133at Greyhound PlatformSLC Gateway
210003Squad 2
210006936?
210009Truck 4
210061Pumper 24
210099Truck 4 see 009
210102truck 22
210107Truck 17
210133Pumper 33
210138Fire Truck 27
210163Fire H&L 5
210169Pumper 19
210293Pumper 1
210430Fire 806
210863Pumper 26*
210882Pumper 14
210883Pumper 24 /2?
210885Truck 17
210888Truck 11
210889Fire Pumper 31*
210891Fire Pumper 8*
210895Pumper 28
210896truck 20
210897Fire unit
210905Fire H&L 6
210908Pumper 33/Truck 30
210910Truck 13
210911Truck 13*
210922Fire H&L 3
210923Fire
210927Fire H&L 1
210929Fire 804
210934Fire Truck 7*
210937Pumper 27?
210938Fire 805
211002Medic 26* / 36*
211009Pumper 24
211029Pumper 29
211034Pumper 1
211035Pumper 2*
2110372 trolley ???
211039Pumper 28
211055Pumper 8
211059Pumper 9
211063Fire Truck 10*
211067Truck 11
211075Pumper 14
211079Fire 7B
211083Pumper 26 / 19
211087Fire Truck 20*
211088Pumper 8
211091Fire Truck 22
211099Pumper 24
211102Pumper 24
211107Pumper 27A
211121Truck 13
211123Pumper 31
211127Pumper 32
211127Pumper 32
211135Fire Truck 35
211139Fire H&L 3*
211144Fire H&L 1
211150EMS?
211151Pumper 26
211154Fire H&L 3
211159Fire H&L 6*
211163Fire Squad 1
211169Medic 2*
211170Medic 2*
211171Medic 5*
211172Medic 5*
211175Medic 10*
211176Medic 10
211177Medic 13*
211178Medic 13
211179Abbott EMS 105
211180Medic 14*
211181 Medic 23*
211182Medic 23
211183Medic 23*
211184Medic 26*
211185Medic 33 / 32 / 31
211186Medic 31*
211187Medic 32
211188Medic 32
211189medic 33
211190Medic 33*
211191medic 35*
211192Medic 35
211194EMS 702
211195EMS 703
211196EMS 704
211197Rover 2
211201Abbott EMS 105*
211217zone base?
211218Rover 1
211223fire
211224fire
211226EMS 127 ?
211236Pumper 33
211257Medic 13
211268Fire Truck 4A or 1A
211270Fire Truck 4
211276Abbott EMS 127*
211278Pumper 29* / Medic 19?
211279Abbott EMS 105* BLS
211529Abbott EMS 136*
211530BLS unit / MedicOne 28
211535Abbott EMS 107*
211536Abbott EMS 112*
211538Fire Truck 30
211539Abbott EMS 136*
211540Abbott EMS 107*
211541Abbott EMS 129*
211545Abbott EMS 112* ALS
211551medic 122
211552Abbott EMS 129*
211567Abbott EMS 136*
211600Ladder 2 ??
211646medic one 22
211660Fire 802
211663Fire 805
211664Fire 801
211665Fire 803
211667Fire 806
211669Fire ???
211765truck 17
212459Fire Dispatch 459
212460Fire Dispatch 460
212461Fire Dispatch 461
212462Fire Dispatch 462
212463Fire Dispatch 463
215500Metro ???
215578Metro Bus on 10409
215600MetroLink Bus Shop ENC?
215627MetroLink Bus Shop ENC?
215629MetroLink Bus Shop ENC?
215632MetroLink Bus Shop ENC?
215772Metro 10407
215948Metro 10407 ENC?
217170Metro Riverboats-Amber
218032Metro Dispatch on 10409?
232004Police D4 unit 419? 711?
232071Police D4 427?
232114Park Ranger
232114Ranger 7
232130PD on SODD
232131Park Ranger unit
232260d4 police unit
232291Ranger Base
232348Police D4 unit
232600Park Ranger Dispatch
232629PD unit
232651SLMPD D4 unit 422
232651d4 police unit
232651Police D4 unit
232651d4 police unit 422
232651PD D4 422
232651PD D4 unit
232651Police D4
232670PD unit poss seargent
232726Police D4 unit
232844d4 police unit
232844Police D4 427
233193Ranger ??
233243d4 police unit 406 (F)
233291Park unit ?
233520PD? unit 9114
233596Ranger 52
234137Police D4
201853Police 7578 ZinklMetro
200493Police 7572 WelleMetro
200469Police 7551 OrtbalsMetro
201816Police 7550 CrewsMetro
232085Police 7557 OfftMetro
200296Police 7574 StrittmatterMetro
200406Police 7576 CarrellMetro
200799Police 7573 ButlerMetro
scanman1958
St. Louis
I have the two scanners that I use in SEARCH mode and have not heard anything on those TG's. I have now programmed them in and activated an alert tone to hopefully alert me.
Is what you hear complete conversations or just a simple single transmission with no reply?
scanman1958
St. Louis
Oh...and are you receiving these transmissions on sites other than 201 and 205 in the city.
scanman1958
St. Louis
I am hearing traffic from NPS in the ONSR TG 3101 and one officer/ranger stated he did not get a response on 'Ozark All'. I checked the MOSWIN DB and did not find that. Could they also use federal VHF channels down that way?
scanman1958
St. Louis
Been monitoring both TG's throughout the day. I have not heard anything on them. Last night I did hear on very quick radio transmission but could not tell who it was. I will keep listening.
scanman1958
St. Louis
10231...tonight I heard SLFD tell a fire company to switch to fire dispatch because they were on FIRE MAIN. I am now guessing that the city will start using a second channel for regular comms similar to SLATER. This will leave the city's dispatch channel dedicated for dispatch only.
I am not sure about 10232 but I have heard the same for EMS. Maybe they will try the same.
Starcom21
I have not been listening like I was before, since I changed jobs, but has there been any actual changes?
Once in a while at home, I'll hear something, but that's it.
