Chris45
- Joined
- May 26, 2004
- Messages
- 144
Recently I saw a STARS template for the Pro-96. This one template listed all of the primary and secondary control channels, and other frequencies together, that are assigned to Richmond, Petersburg, Louisa, Warsaw, Rumford, Thornburg, Fork Mountain, Hampton, Williamsburg, Chesapeake, Franklin, Burgess, South Hill, Cumberland, and Leigh Mountain. Some of the other frequencies were current conventional frequencies, so there was a programmed mix of FM and MOT frequencies together. The extended tables, while not marked VHF, 3600, or 9600, reflected the custom tables for the Pro-96/2006 in the current STARS database.
I did not realize that this trunked system could be programmed this way, but to my amazement, it seems to work at least for Thornburg. I live in Spotsylvania, so the Thornburg signals come in good. I am hoping to verify this template configuration is the best one to use. For example receiving both trunked and conventional radio traffic, and with the custom tables lacking a baud assignment. Can such a grouping of frequencies and control channels work this way in the Pro-96?
Thanks in advance.
Thanks in advance.
