As I'm no expert and learned many thing here. I would like to start fresh with my radio, I have no particular system/favorites. I am currently at "Nothing to Scan". Is there a way to find and save anything that is in my range to receive?
The entire Radio Reference database is already in your scanner. Be sure to connect your scanner to the Sentinel Software and update the database. Enter your zip code into the scanner, and you will get a lot to scan from your area.As I'm no expert and learned many thing here. I would like to start fresh with my radio, I have no particular system/favorites. I am currently at "Nothing to Scan". Is there a way to find and save anything that is in my range to receive?
In Sentinel, edit -> add channels on range. Put your gps coordinates in, pick a range, select service types and create a new favorites list.
If you press Menu > Set Scan Selection > Select Lists to Monitor. Make sure "Full Database" is On if you want to only scan by zip codeAs I'm no expert and learned many thing here. I would like to start fresh with my radio, I have no particular system/favorites. I am currently at "Nothing to Scan". Is there a way to find and save anything that is in my range to receive?
Did you set up your location in menuAll Service Types say "-". I was trying to manually turn them all on.
Got it, thank you. Is there a way to set to ID Search instead of Scanning?
Probably lots of ways to find your gps coordinates, but what I use is google maps. Find your house, right click and a pop-up with give you gps coordinates.
There is no simple answer to travelling. You could buy a gps puck for scanner and enable full database. You could create separates favorites that you enable/disable with quick keys for the counties/areas you frequent.
I'd suggest you concentrate on getting your home location right before worrying about leaving home and scanning.
How do you enter your coordinates when you have an extra digit?
With a GPS device, with your phone, looking up the zip code of that town, etc, etc......Or best of all just buy a GPS for the scanner.How do you find your coordinates and what if you leave your county?
