I tried messing with ADSB a year ago, was half way successful using a RTL Dongle. Its been so long I don't recall where to start anymore, using a PC, WIN 7.
I know the dongles work as I use one with an upconverter on HF frequently, so I'm that far.
So to the question, if you were starting over what would use today?
From my reading it sounds like I would use/need:
Dump 1090
planeplotter / Dump1090
Use this guide to get Dump 1090 working
PlanePlotter
Also would need Planeplotter
PlanePlotter from COAA
Does the above look to be the right track or should I look at something else?
As a side note, I'm going to trim one the antenna that came with the dongels, if I can get it working I will look upgrading, the goal for now is just be able to see the planes flying over my head!
Dump 1090
PlanePlotter
