SDS100/SDS200: Static when streaming
Nogard
Anyone have suggestions on how to get rid of static when streaming to a laptop with an SDS100 and audio cable from headphone jack (scanner) to audio in (Primary Sound Capture Device)? It's actually a distinct sound that I guess can best be described as static that I only hear when the device is scanning.
I've tried two different cables although both are pretty thin - perhaps I need a higher quality cable?
Thanks for any advice.
Nogard
Just to clarify - the static I'm hearing is only when streaming through the Proscan software; the SDS100 itself is not having an issue with static...
Thanks.
Nogard
FYI - I purchased a higher quality audio cable and that helped a lot with the static I was hearing. Will also be purchasing the product linked above as well.
Thanks to everyone for the help.
cnmsales
Waynesville, MO
If the hum goes away when you unplug the connection - most likely - yes.
I've seen at least 3 cases so far where the filter removed the hum.
Thanks for the info. Yeah the hum is only present on the stream. It's not horrible on mine but anything I can do to make it more clear.
