Stepsize and bandwidth SATCOM
Saint
Fort Erie Ontario Canada
I want to search between 240,000 and 270.000 MHz for pirates and others, I am running SDR# 1919 Studio software. Is this the way to setup to scan the frequencies.
NFM
StepSize=12.000
BandWidth=25.000
or is this wrong, I am using my Discone antenna, I do have a longwire outside also, any pointers would be helpful.
Steve
Saint
I would search 243.5 to 270MHz, 25KHz step size and 15 to 25KHz BW is good. You might tilt your Discone mast to the North so it has a better radiation pattern upwards and to the south.
Thanks so much for the info, I changed my settings to 25-bandwidth and 25 step, I'll see if I pickup anything, I have my discone on my fourth floor balcony facing north.
Steve
prcguy
Steve
From your location the satellite arc will start from the south east at the horizon to due south up about 30deg elevation then back down to south west at the horizon. You will need an unobstructed view of all that. A balcony facing north with a building in the way to the south will probably not work.
Saint
some tops of trees are in my way but no buildings, when I go out on my balcony I see north, east, west, When I first started to scan the frequencies I did pickup a voice, but I did not move fast enough to see what frequency it was, it only lasted for a few seconds and never found it again. Than was about an hour ago, 9 - PM 21:00 UTC
Steve
mancow
N.E. Kansas
Just be aware most of the pirates seem to use a 10 or 20 k step so they often end up a bit off centered in the transponder.
mancow
N.E. Kansas
No, stay with the 25. I'm just saying it's something to be aware of if seems you can't quite tune them in.
dlwtrunked
You beat me to saying the same thing. But if you go by the 25 kHz steeping, using search mode does not really make since as the channels of the "bent pipeline" down link are generally known and scanning them will be faster than using search mode.
(I need really no say I hope, that using an SDR and waterfall display is really, by far, the best way to look for this activity. You can see the channels with noise in the always on downlink and at the same time tell when an FM signal takes over that channel.)
prcguy
Steve
Your Discone needs to see east to south to west. A Discone can pick up some UHF satcom but you will need an antenna that has more gain and/or right hand circular polarity to work the best.
Saint
Yea I thought the discone was pointing the wrong way I have the same problem with trying to pick up the satellites in the HF bands also, This is a video of what I am seeing on the waterfall.
Steve
mancow
N.E. Kansas
The newer UHF Follow On satellites are pretty hot and can be picked up on Discones and handhelds depending on look angle. Some of the older sats need a lot more antenna to get a useable signal.
Pimp him your homemade antenna plans. It works well.
Saint
Yea on HF, when trying to pick up the marine and aircraft, I had to put the little antenna I bought on a long stick and take the screen of my window that faces SOUTH to pickup anything. But that's not practical it lets bugs into the apartment, also a little cold in the winter time so I gave up on listening to these satellites . I did pick up a little audio on the 240-270 MHZ band for a few seconds but it was in scan mode and I never found anything again.
Steve
mancow
N.E. Kansas
Well you aren't missing anything. It's just static and morons speaking Portuguese.
Saint
Kind of thought it was like cb radio, it was a lot of fun in the 70's but it turned into a three ring circus with too many clowns out there.
Any way there is a lot of other things to listen too. Thanks everyone for all the help in answering my question.
Steve
