HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
Nighthawk-31 flight of two just cleared PHL airspace heading south. Prior to hearing them with ATC, I heard a lot of rumbling in the distance like I have when Ospreys have pass through recently.
McGuire space A has C-17's to Cherry Point MCAS Tues and Weds and Dover did have one listed for Weds
but since taken down. Saw blurb this morning from UK that mentions Cherry Point F-35B's will deploy RAF Marham
by end of August. RAF Marham is where the RAF F-35B's call home.
Must be taking full squadron perhaps if they are loading up multiple C-17's for men and gear.. Lots of tool boxes.
Sounds like Coronet job for McGuire KC-10's with their multiple drogue hoses unless Marines want OTIS KC-130J's.
I think KC-10's would be quicker.. Course maybe 2+2 =5 so not sure :)
1600 local CATBIRD 1 C-20 #165151 inbound Andrews after Lajes stop via the Med going to Navy ramp 4 crew,7 pax
1820z RCH 601 C-130J 08-5712 317AW Dyess inbound McGuire on CP 237.150
There is a Navy P-8A VVLL882 working low pattern at Atlantic City up from Jacksonville.
mdmonitor
0920- Air Force 2 (C32 # 98-0002 ADFEB8 1st AS) off ADW heading west.
0925- DeeCee 21 flt (3 X KC-1356Rs 756th ARS) off ADW heading south. Working ZDC Patuxent (133.9). Unusual to see flt of three KC-135s. They went down to Norfolk area then looks like they are going out to W386/W122.
Turn on radio at 14:30 local and have what sounded like Zero Delta 1 with Pot appch 317.425
then pushed something .100 no joy so given 250.300 and down to 3k feet last heard.
Nothing on adxb site.
mdmonitor
1929- SAM 308 (C-37 # 97-0400) land at ADW. Departed from Arnold AFB TN.
1935- SAM 328 (C-40 # 01-0041 AE11F6 89th AS) land at ADW. Departed from Anchorage AK.
1935- Topcat 7 (KC-135R # 62-3578 AE07BE 108th ARW WRI) check in w/Giantkiller (118.125). Presently at FL300 but will descend on way in to the IP. Heading out to W386/W122.
AirScan
Something going on in BGR or staging for something ?
SPUR 86, KC-135, 63-8026 (151 ARW), SLC-BGR, arrived 23:30 EDT
SPUR 87, KC-135, 59-1450 (161 ARW), PHX-BGR, enroute (over YYZ 2345 EDT)
SPUR 88, KC-135, 59-1453 (186 ARW), MEI-BGR, arrived 23:05 EDT
SPUR 90 inbound KDOV 0310 local KC-135 58-0071 6thAMW/927ARW.Req parking,follow me, crew trans.
Sounded like they were staging in no hurry.Maybe something for Weds night?
Note all KC-135's are National Guard types...
mdmonitor
Guys,
I was chatting with Larry Van Horn about the DC ANG UHF freqs.
Here is his reply:
The three are very interesting.
238.175 is a nationwide ACC A/A and a Vacapes opera freq. So this is probably mission not an assigned sqdn tac.
285.225 is a USN Ship/aircraft ops freq for 2nd and 3rd flt. Again this looks mission not an assigned sqdn tac.
319.175 this is an AMC Atlantic TACC Random CR Plan freq. Again this looks mission not an assigned sqdn tac.
Not saying these aren’t sqdn tacs, but the assignments above are nationwide and the 285.225 is a definite USN fleet support channel.
But I have put them in the db and sourced them to you.
Winking smile
BTW had an interesting interchange on twitter this morning about a Score 92 flight in your backyard.
The original poster mentioned it was an MQ-9B, which I thought was interesting. Another said E-2D.
It all revolved around the hex code block AE2FD0-AE2FD8.
Yes, I know that Score is the VX-20 c/s. But Score 92 is not unique to an E-2D only. I have seen one of their F/A-18 use it.
Also the navy has been experimenting using the MQ-9 as a relay platform for sonobuoy / ASW mission.
So you and the MD gang might want to keep an eye on AE2FD2/D3/D6. I’m not saying 100% that these are static and used exclusively or ? I am inclined to believe that the three hex codes above and in this block could be used randomly for various platforms and NOT assigned to a particular airframe.
I am watching it but you guys are closer to this than me.
jsoergel
Cincinnati/Dayton, OH
Guys,
Here is his reply:
Winking smile
I can confirm that DC ANG used 238.175 while in Michigan for their exercises last month and I believe they referred to it as an aux preset. I think it is a squadron tac.
I can also confirm that 319.175 was used by DC ANG during a cross-country (without tanker support) and was also referred to as an aux preset. Near me, it is used by IN ANG as one of their squadron presets.
krokus
Southeastern Michigan
The 927th is USAFR. They used to be located at Selfridge, but moved to another facility, down south, and transferred the KC-135s to the 127th. (Some of their personnel transferred, too, as they did not want to change drill sites.)
Yes see 927ARW fly out of MacDill AFB still using training callsign like BOLT as homage to their Detroit lineage.
I think may be for Langley F-22's enroute Lakenheath.. Seems every time they spot a tanker
at Dover it is for Langley Birds. Prob another out of McGuire will meet them off Snow Hill MD
and run them up to Bangor area testing A/R etc along the way.May have a spare or two as well.
They almost always like to start out early say 3-4 am local as well. Usually the one time F-22's are not stealthy
as they add two ER wing mounted fuel tanks to make the long trip.... Will try and follow them if awake :)
