mdmonitor
Maybe setting up for someone large and thirsty?I know when they work Carib refueling almost always use SPUR 50-54 numbers.
Maybe Spur 73 heading for Bangor?
Looks like KPSM for the touchdownMaybe Spur 73 heading for Bangor?
These are not one and the same. DCM= "Dotcom" = FltPlan.com Allows flights to operate with the Dotcom callsign to obfuscate tracking. These flights are not available for tracking on Flightaware either. No associated plane registered to 4185D. It's reserved by the FAA's Surveillance and Broadcast Services office. Maybe they're maintaining some regs to be used for privacy like this?
Look at the speed of the DCM flight, clearly a jet not a C-130. Also returned to MDT a few hours before.
DCM4140 http://archive-server.liveatc.net/kmdt/KMDT1-App-Dep-West-Oct-12-2020-1600Z.mp3
BATON74 http://archive-server.liveatc.net/kmdt/KMDT1-App-Dep-West-Oct-12-2020-1830Z.mp3
No mention by ATC to other traffic that would ID the type. I didn't check tower or ground comms.
1700- Both 82-8000 & 92-9000 off ADW heading south.
Fast service Sanford to DC in about hour and a half?Headed home with 92-9000 in the lead
I know it was listed wrong, I maintain a DB of hex codes for reference.Okay let me try this again. The mil hex code should have been listed in my report as AE0248 Tail 96-8154.
No. You saidDoes that clarify things better ?
Odd Air Res up in AR-20 this afternoon noon local.. First Eastbound track then Westbound..Looks like KPSM for the touchdown
Question now is why Travis KC-10's on this upcoming hop.
Maybe will get a SPUR 71,74 later out of McGuire to assist?
No. You said
DCM4140 (A4F4E3) departed KMDT and heading southwest. Shows as 96-1854 a C130 on flightaware. I read that as you saying BATON74 is using both hex codes and they are not two completely different aircraft.
My logs for the 180th FW Coronet:
