Strange beep
kjfswkr
New Hampshire
Hi all,
I have a 536HP and last couple of weeks I have been hearing an intermittent beep. Any ideas what it may be?
Thanks and 73'
Kevin
ProScan
Software Provider
Ontario, Calif.
Hi all,
Thanks and 73'
Kevin
If you're using ProScan, is the Resume Scan/Search turned on?
Whiskey3JMC
Simulcastylvania, TE
Is close call enabled when you hear the beeping? What does the screen say when the scanner beeps? Too many unknowns to know for sure but for me personally, the key beep is the first thing I disable whenever I get a radio: Menu > Settings > Adjust Key Beep > Off
tvengr
Well Known Member
Baltimore County, MD
If it occurs on the same frequency or talkgroup all of the time, check that you don't have an alert enabled on that frequency or talkgroup.
Ubbe
Stockholm, Sweden
The only time time I know that the 536 beeps are with an error, that the SD card have a problem to store or retrive data or something similar.
The display says nothing at that exact moment, but perhaps you don't have eyes on it right then and only hear the beep?
/Ubbe
kjfswkr
New Hampshire
Thanks guys. This is mounted in my car and when i hear beep i dont notice what freq it is on, etc. will try to observe a little more n let you know.
kevin
phask
zanesville
You CAN program an alert beep (per channel). I did that once to alert for a rarely used channel. It switched to frequent use when I was mobile... ANNOYING.
