Baofeng Strange CPS Language
kd7one
Billings, MT
I downloaded the latest programming software for the Baofeng DM-32.
When I opened up the CPS, I got this strange language. What went wrong?
dave3825
Suffolk County NY
This forum is for software defined radio.
Try uninstalling and reinstall. If that fails, reach out to Baofeng.
kd7one
Billings, MT
Arggh. I realized I put this post in the wrong place and don't know how to move or delete it,
dave3825
Suffolk County NY
Where did you download it from? Baofeng direct or some other web link?
K4EET
Chaplain
Severn, Maryland, USA
From the characters seen in the screenshot, it appears that you do not have the correct font installed for the software. It does not appear to be a foreign language at the moment. It could be Chinese characters and you do not have that particular font installed to display the Chinese characters correctly.
K4EET
Chaplain
What went wrong?
I’m back again… I wanted to let you know that I installed the CPS for the Baofeng DM-32UV HT and I got the same results as you did. A bunch of alphanumeric characters. I also went through all of the menu items to see if one of them might change the displayed language to English. That was a negative. It appears that the CPS is only coded for the Chinese language. Looks like this may be a losing battle. Sorry. You could contact the seller or manufacturer and see if the CPS might be available in the English language. Chirp Next does not have that HT model number so that is a no go as well.
KJ4DHF
Baofeng DM-32UV 1.45 and 1.60 CPS on my side can be changed to English no problem.
QPLou5645187
San Antonio, TX
[function]
domodal=0
russia=0
fanti=0
langdefault=0
langenable=1
lang=en
Actually, if you go to your CPS ini file and change the lang to en, it will correct your problem. Open the ini file with notepad and save your changes. Open your CPS software and now it should show in english!
