Strange filter / Multi-coupler problem
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
BLUF: I have been battling what I thought was some kind of power interference problem for about a year. This "interference" is primarily in the VHF band, from about 120-155 Mhz. I do not live anywhere near any FM broadcast towers. Nearest cell tower is a few miles away. I do not have any battery backup / APC units nearby. The computer used for running SDR in the below pictures is a 2018 Dell i5 desktop mini-tower (not the micro station with the notorious power supply)
Hardware: DpDproductions Omni-X, roof mounted, cable is LMR-400 (50 feet) professionally terminated. Feeds two inline PAR filters - one for 88-108 FM broadcast and one for NOAA 162.55 mhz weather. (more on this later) which feed a Stridsberg multicoupler. Receivers are several Airspy SDRs, iCOM 8600, and 4 scanners. For the purposes of the pictures below, all have the same bandwidth, same Airspy SDR, same gain levels, etc. Nothing electrically is changed in between configurations.
this is what that setup looks like: (sorry for the dust) LMR400 comes in, goes into FM Broadcast filter then the NOAA filter, then into the Stridsberg and out to the radios.
82713
This is a normal spectrum sweep 120-ish MHz, 8Mhz range, mid-way gain, etc. with the LMR-400 coming down, going directly into the two PAR filters and into the multi-coupler (as shown above). Note the "spikes" of noise about every 250khz or so. These do have modulation, "bzzzeeeP" and pulsate at about 1 hz or so. Yes, I see this same effect on the spectrum analyzer of the iCOM 8600 and can hear it on VHF "pulsing" on the scanners.
82712
Here is the setup with the antenna cable disconnected and a 50ohm load in place of the antenna feedline. Zero noise floor, as expected.
82715
now here is a picture of the setup running with the NOAA filter installed --- but the FM Trap REMOVED: (Note the "spikes" are gone but the noise floor did go up about 10db)
82716
Some of you may go down the path of "hey, it's fixed - move on" --- well, it's not. For some reason, even though I am no where near any high power FM broadcast stations, I must use an FM filter for the SDRs ---- I have horrible amounts of intermod and bleed that occur in the military aviation band (specifically in the 280-320 Mhz range) ... so I absolutely MUST use an FM broadcast filter if I want to listen to mil-air.
Next you might say "Contact PAR Electronics" - already have. Dale is INCREDIBLY responsive to emails.... and we've been working on this most of the day... we don't have any ideas yet....
Next you are going to say that I should swap out the PAR FM filter trap. Tried that too.... I did a test where I replaced the PAR FM trap filter with the little crappy RTL-SDR FM trap filter... guess what? Got the same interference/mix/high noise floor symptoms.
or you might say "the multi-coupler is bad" - nope, took that out of the antenna feed path = no change. still have the noise floor problem.
The only common denominator here --- is "A" FM filter/trap (doesn't matter if it's the $100 PAR or the $18 RTL-SDR one) - being in the antenna feed path --- causes the noise floor to go crazy........ and I have no idea how a passive circuit like an FM trap could possibly be introducing stray RF into a SDR receiver front end.
open to ideas.
Not sure, but "Passive" devices can be a problem, especially if you have strong signals in the area:
spanky15805
Seen something similar to that recently. The "fire breathing FM broadcasters" have in the past year and half have done a 180 and are now throwing up 99 watt stations like crazy! So, you are going to have to do an FCC database search to see what shows up for your lat/long. I keyed on your 122,246 screenshot. Listen to it and see how many stations are there.
Ubbe
Stockholm, Sweden
Look for the strongest BzzzzzP signal and enter that frequency in a portable scanner and go outside. Hold the scanners antenna horisontal pointing away from you with your body behind the scanner. Open SQ and listen to the signal and swirl around to find the weakest signal and the antenna then points at the source.
Change location and check if it points at the same source again. Repeat the process to pinpoint the source.
I have the same problem in VHF, but constant carriers without modulation at 100KHz intervals, and source seems to be neigbours solar panel installation.
The reason the spikes doesn't show without the FM trap filter are that the receiver loose sensitivity when it receives stronger signals, SDR dongles much more so than a scanners proper receiver.
/Ubbe
batdude
Moderator
Do you have any screw in LED lights nearby, especially the ceiling can flood type? Some brands completely rip up the VHF band.
i should have mentioned that I have tried the "shut down the house" and run off batteries method - signals/interference did not change.
batdude
Moderator
i have no idea what you are talking about. Could you provide me a link or something so I can read up on this?
thx
d
buddrousa
On ebay and other sites you can buy a FM transmitter and run the power up and have your own 100 watt FM Radio Station (Outlaw Stations) is what I this is being said.
batdude
Moderator
/Ubbe
I don't really have a "strongest" interfering signal - at least not one that I can find. best way I can sum this up is "broadband interference"
For the other readers in this thread - I did have Spectrum CATV and Florida Power come out for a survey - and I actually met both of the technicians... who were most certainly knowledgeable - no solid sources of interference were found except for a few leaky CATV boxes that he fixed on the spot. I do have a street light in the front yard - wanted to make sure it wasn't leaking RF... and it's not.
Also - in regards to solar installations --- I was thinking this too - but if this was the case, I should see a noticeable drop off in the evening - which I do not. There are periods where the noise is diminished or nearly gone --- but it doesn't seem to correlate to day/night or any kind of specific schedule (like someone's pool pump turning on/off each day) ....
doug
Ubbe
Stockholm, Sweden
OK, I thought you had spikes at a 250KHz interval, but I guess I was wrong. Then it's harder to find but what if you set a scanner to AM and listen for the noise level in the frequency band where you have the highest "bump" in the spectrum and tune up and down the frequency to try and hear a difference. Then you perhaps can locate a source.
If you see the interference on two different receivers, although they are connected to the same antenna and splitter, it should come from an outside source. Just to be sure you could put an attenuator between antenna and splitter, a 6 or 10dB one, and see what happens to the interference. If it only drops the same amount of dB it's probably a genuine source that the antenna receives. If the interferency dissapears completly, or doesn't change at all in strenght, then it's an internal problem with your splitter or power supply or something in the house.
Have you tried to bypass the splitter and connect the antenna coax directly to the 8600?
/Ubbe
dlwtrunked
open to ideas.
This is only tentative speculation but I think it is possibly what is happening. The main effect of a strong signal (like FM broadcast) can be to de-sense the the receiver. Using that hypothesis, when you do not use the FM Trap, your receiver might be de-sensed and you are not seeing the true noise floor. Putting in the Trap, un-de- senses and now you see the noise floor of weaker signals.
batdude
Moderator
/Ubbe
i just tested the R8600 direct to the antenna coax, bypassing the multi-coupler and filters. same noise.
it is not something inside my own house. I have turned off the master breaker to the home and run the icom on batteries - noise is still present.
d
batdude
Moderator
you are probably correct. the funny thing is that I do not have any - ANY - "nearby" FM broadcast transmitters....
d
dlwtrunked
d
This would tend to support my hypothesis. Does it appear 24 hours a day? How close are neighbors? How close are power lines? (buried?)
batdude
Moderator
typical suburban neighborhood. underground power. no neighbors within at least the first couple of rows that have active (power) solar collectors....
see post above - the noise does sometimes diminish --- but it's not on a schedule (like a pump on a timer, etc.)
d
batdude
Moderator
Since its VHF you could buy or make a couple element Yagi or make a null antenna and use that to get a bearing and hopefully pinpoint the source.
unfortunately, you are probably correct that this is what I will have to do.
