Strange noise
When I am listening to the scanner it makes this buzzing noise ocationaly on random talk groups and I never hear this on the radio. does anyone know what this is? (BTW it is the LCRA Truncking in Central Texas)
bwhite
Carroll County, MD
Is it an EDACs system?
If so, you can hear this stuff if your frequencies are programmed out of order.
Also, some of the talkgroups no matter what kind of system are dedicated to data transmission
which will result in the nasty sounds, if you can isolate it to a talkgroup or 2 that's probably the
cause; delete them or at least lock them out.
It is an edacs system but i checked the order of the freq's and I have programed it to only scan talking channels it will be on PD disp and SO Disp so I cant figure it out.
JoeyC
Senior Member
San Diego, CA
I get occasional Bzzzzzzzz sounds that preceed a transmission on an EDACS system at the beginning of a transmission that is patched across more than one talkgroup. This occurs on all of my Uniden scanners.
studgeman
I have not come across a scanner that does this, but FWIW EDACS systems sometimes employ a digital or digital encrypted voice and also data on the system. Scanners are programmed to ignore the digital talkgroups and other data on the system. theses are beeps and buzzing normally associated with trunked systems. It could be you have a fluke in your scanners software or there is an non-standard setting on the controller which the system radios have no problem with but you scanner has an issue with.
Just some For What its Worth thoughts...
