Wondering if any folks out there have experienced what I am hearing. I have owned the 796 for a few weeks now. I'm in the West Palm Beach, FL area monitoring APCO 25 Trunked Palm Beach County frequencies. With the standard antenna (I have tried various lenghts) while I receive the transmissions OK there is some signal degradation every few seconds. The channels do not cut off totally but static comes in and out as the signal strength seems to go from strong to moderately weak. I am on the 2nd floor of a 2 story house and the 796 is near a window. I even bought an 800 mhz antenna with 2.5db boost and that did not help at all.
The strange thing is through some trial and error I hooked up an old GRE 20db Super Amplifier at first with the whip antenna which helped a little but not much. Then I removed the whip so now all I have is the amplifier hooked onto the rear of the 796 with NO antenna attached to it and the reception on 800mhz is excellent! What is going on here? The bad part is I don't think I'll be able to use the scanner for anything but 800mhz in this set up. Thanks in advance for any feedback.
