Strange XTL1500 Interface Issue
70cutlass442
I am building a simple P25 to analog repeater. I am using a CM200 for the analog side and a XTL1500 for the P25 side. I built this originally with an 800MHz XTL 1500. It worked great.
I now put a VHF XTL 1500 in and it puts the CM200 into TX. Both of my VHF do this, but not the 800.
Does anyone have an idea as to what's causing this? the XTL does not have many settings to adjust such as active high/low which was my first thought.
jeepsandradios
East of the Mississippi
Check COR on the XTL. I dont remember what versions changed but ran into this with our interop boxes years ago. I tend to think the 800 was active high and the V/U were active low. Your using Pin 13 correct ?
Edit...
From an older manual -
13 CHAN ACT Channel Activity 0-5 volt output used for indicating detection/
unsquelching of a qualified received signal. As of the
release of this manual only UHF R2 is APCO
compliant active low.
70cutlass442
Edit...
Got it!
So, the 800, on pin 13, is active low. the VHF is active HIGH.
Since I WAS using a CM200, this project would not work as the CM200 will not let you change the input bias. I changed to a CDM750, changed to active high, and we are set!
The XTL also does not allow for changing bias in the software.
