all day today my feed has been messed up. i don't think it's an ISP issue as i work for the ISP and connection is stable.\
I've tried both proscan and scannercast same issue....at a loss of what to try next
disabled all AV/FW, ports are configured correctly on router.
it's been stable for a couple years. i wonder if the server can't reach me? in proscan i can see the total bytes TX and RX and RX never updates
Code:
27-Dec-2019 20:53:30 Connection complete to RR server audio9.broadcastify.com/07zrtgxpwj48
27-Dec-2019 20:58:06 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
27-Dec-2019 20:58:06 Disconnect details follow (for debugging if necessary):
Message: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
Source: System
TargetSite: Void Write(Byte[], Int32, Int32)
StackTrace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at ScannerCast.ScannerCast.PushClientThread()
--Message: An established connection was aborted by the software in your host machine
Source: System
TargetSite: Int32 Send(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags)
StackTrace: at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Socket error: 10053
