Tweekerbob
- Joined
- May 27, 2004
- Messages
- 614
Keith,
Do your have your NO-IP addresses set-up as a Port 80 redirect with no-ip.com? It seems like at least with the pinellas one you do. I can't bring up the county one. So whats happening is that when someone clicks on http://pinellas.no-ip.net , the no-ip server is connecting the "web" request, which should normally be on port 80, to your ip address on port 8000. This is not what you want.
Go to no-ip.com and log in to your account. Click on the little blue arrow on the left hand side next to Hosts/Redirects. With that expanded, click on manage. You should then see the redirects you have set-up. For each one, go into modify, then under Host Type, change it from Port 80 redirect to the first choice which is DNS Host (A). Also, while you at it, download the free Dynamic Update Client (DUC) from their website as well, install and properly configure that.
The second thing you need to do is in your icecast config file, and I mentioned this to you before, change the <hostname> setting to your no-ip address like, pinellas.no-ip.net. Pick one, they both point to the same computer.
Lastly, when you've made the above changes, you can access your feed by clicking http://pinellas.no-ip.net:8000/live
Oh, you can be more descriptive with the mount names if you like, maybe call one /pinellas and one /county.
