Streaming from SDS200
Ret_Batt_Chief
Windsor,ca
Router is on other side of house. Is it possible to stream from SDS200 without using Lan cable. Which is better, using the headphone jack or rear external speaker jack using a USB Sound card. Will be using Proscan.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Ret_Batt_Chief
Windsor,ca
Was trying to avoid router issues, port forwarding etc.
Currently stream from a BCD436 from headphone jac to usb sound card. Was hoping to do the same with SDS200.
Ret_Batt_Chief
Windsor,ca
Moved the router and got the Lan connection set-up. Now streaming two separate streams to Broadcastify, but the audio from both streams is from one stream. Alpha display is working and shows connected but no audio from the SDS200
