Stridsberg Multicoupler Failures
iMONITOR
Silent Key
S.E. Michigan
It's surprising to hear of the problems some have experienced. I've always known Stridsberg to have an excellent reputation. Of course, any device within the antenna line is subject to damage from lightning, which can't be totally prevented.
I did find this on their website, if it's of any help:
Warranty
Products manufactured by Stridsberg Engineering are warranted to be free from defects in workmanship or material for a period of three (3) years.
Defective products within the warranty period will be repaired or replaced at no cost to customer.
For service and repairs, return defective units shipping prepaid, to:
STRIDSBERG ENGINEERING,
354 ALBERT AVENUE
SHREVEPORT, LA 71105, USA
cmdrwill
So Cali
I know I am bring back an old topic, but does anyone have the info on the Fuse Marked "FC"? Speaking of the one that w4rtt mentioned. Mine went and need to replace.
Thank you
How much current does the coupler draw? The internal fuse would probably be twice that value.
And any transmitter near by would over load the coupler and cause component failure.
oldtimeradio
Stafford Springs, CT
I have a 4-port version
Only once in the 10 years I owned the 4 port version I had a failure.
Lightning.....
I found a front end RF replacement from Mouser, bought about 6 for spares.
Worked fine.
Also RF Preamplifiers - Spare Parts
Communications Technician for 45+ years.
W1DMX OTR
VK2GEL
Hi, is Stridsberg still in business and repairing MCA104's? Mine is deaf.
It doesn't look like they have updated their web pages since 2013.
Thanks, G
kruser
Well Known Member
W St Louis Cnty, MO
Thanks, G
Yes, they are in business.
The website has been updated with newer models of several products recently but John may have missed updating the sites date that is displayed.
I own several of their products and they are built very well.
When I had problems, they always repaired them for free even if caused by myself from accidently transmitting through their preamps or multicouplers.
John even sent me spare RF transistors for free so I could repair them myself so I was not wasting his time fixing my mistakes.
He even made me custom preamps with less gain than his production models.
edit: Common problems I've caused with the MCA104 is blowing the RF amp by accidently transmitting back through the multicoupler. They do not fare well if you do that even with just a watt or two.
In one or more cases, when I took out the RF amp, it also took out the 8 VDC regulator he uses in many of his products.
The RF amp can be purchased from Mouser or Digi-Key and the 8 volt regulator can also be obtained from Mouser or Digikey
They also contain some resistors used for setting the bias and also tuning the freq range of the coupler as well as some SMD capacitors of which I forget the value of now.
Some of the caps are used to set the freq range and some are simply there for filtering.
The MCA104M should be capable of being powered over the coax as well as using a wall wart of 12 VDC plugged into the 104's power jack.
They only draw a very small amount of current so a 12VDC wall wart with just 100mA current rating will power the 104M with no problem.
I power all my Stridsberg amps and couplers from a common battery backed up power distribution system I custom built that also powers my many radios so I can keep my station running for hours or even days if I lose utility power.
Some of my older Stridsberg preamps only draw about 10mA and I think most of my 8 port couplers may only draw about 50mA.
Send John an email and he will often tell you what part number you need if you want to repair the unit yourself or he will offer to sell or even give you the parts needed. You just need to be skilled in working with SMD mounted components. If you want it done right, send the 104 to John and he will replace the bad part(s) and make sure the correct frequency range is maintained. Too much solder on some of the stripline boards he uses can alter the frequency range of the RF amp for example.
The RF splitters he uses do not often fail even if you accidently transmitted through the unit. The splitters are usually made by Mini-Circuits and are pretty robust. I've never had an internal splitter fail.
Also as has been mentioned in this thread is failure from nearby lightning strikes.
That will take out the RF amp and sometimes the regulator.
I once accidently stacked two preamps in front of a multicoupler and that produced too much input at the multicoupler which toasted the RF amp.
The 2nd preamp handled the high RF levels from the 1st preamp without toasting it also.
kf7yn
West Jordan, UT
FYI, Stridsberg will update your multicoupler to the current version at no cost as long as you own it. I've had my MCA204M updated several times and it's at least 10 years old. I have had no failures. Great company to work with.
Ubbe
Stockholm, Sweden
It's a fast acting fuse. As the multicoupler have stabilizing capacitors it will draw a quick surge when connecting to the power source. This will "wear out" the fuse and it will eventually fail.
Replace it with a fuse of your choice that are marked 1A or 2A that will leave plenty of margin.
If you bridge the fuse with a wire you will not protect the components from damage if the power supply fails in a way that will input unregulated power. Or if a capacitor shorts out in the coupler it will damage the power supply if it lacks fuse protection.
/Ubbe
VancouverScan
White Rock, BC
Stridsberg is a Great Company
Same here, my first MCA204M was purchased in the mid 90's and just sent it in because they told me they changed a few things, mine was working fine, I sent it in and they returned it with all new components, FREE. I just purchased the 8 way active multicoupler as well as the 4 way active for HF. The only other couplers that are superb in performance cost Thousands of dollars, unless you use a TV multicoupler, which are cheap but you get what you pay for and the isolation is not near as great as these.
