Stridsberg Multicoupler Mount
JM707
I recently acquired a Stridsberg multicoupler. Rather than screwing it to the wall behind my scanners I opted to build a mount that hooked onto the shelf supports so I could reposition it if necessary. It’s made of scrap aluminum I had in the shop. I couldn’t find any specs on the Stridsberg web site showing the mounting screw spacing. Turns out it’s about 125mm x 36mm. The holes for the screws were drilled and tapped 8-32.
tvengr
Well Known Member
Baltimore County, MD
I have my MCA204M Stridsberg multicoupler mounted inside the wall in my family room. I cut a hole in the drywall and installed a 3-gang plastic electrical box. I drilled holes in a blank metal cover plate so that the 4 BNC connectors of the multicoupler come through the plate. The coupler is mounted to the cover plate with homemade brackets. There is also a jack on the cover plate to plug in the 12v power supply for the coupler. I have a 25' LMR-400 cable run from the attic antenna which comes down through the wall into the back of the electrical box. My scanners are in a bookcase at the end of a couch. I used hole saws to cut access holes into the side of the bookcase which is about 6" from the cover plate. There are 3' RG58 cables from the coupler to the 4 scanners. There is an AC strip mounted on the side of the bookcase for the power adapters. All of the antenna and power cables are routed through the access holes in the bookcase and are run behind the scanners. There is also another AC power strip on a lower shelf of the bookcase for a 5 output USB power supply, a Unication amplified charger, and any other power adapters I may need for other scanners.
