Stryker 955 plus
WSAC829
Jack of all trades. Master of none.
EN64ak
By default with no modifications it mainly covers 28.000 - 29.700 (and 24.890 – 24.990) as it’s sold as a 10 meter Ham radio.
After the modification it will cover 25.615 - 30.105 which will cover most of the 10 / 11 / 12 meter bands. (CB is 11 meter)
Full chart is here:
The CB band would be Band D (26.965 - 27.405 = channels 1 - 40)
WSAC829
EN64ak
Is it a good radio, I'm considering getting 1, also can a guy do the conversion that they talk about?
It’s subjective. Some love them, some don’t. Honestly the Radioddity QT60 Pro has all the same features for half the price and is easy to modify yourself (see youtube). Everybody locally here with a Stryker paid to have theirs converted, so i don’t know what's required to do it on a Stryker.
Dirtblaster44
Minnesota
WSAC829
EN64ak
The video i posted above shows you how to do it. Solder in a jumper wire, then push and hold some buttons and power on. Done.
WSAC829
EN64ak
The 955HPC+ is the latest version (v3) with extra power, features, and improvements that aren’t found on the older versions. A quick Amazon / eBay / g00gle search of the will tell you the specific changes/additions the new version has.
The Stryker 955HPC+ claims it does 100 watts, so i wouldn’t recommend using anything less than a 20 amp power supply to be safe.
Dirtblaster44
Minnesota
Ok my next question is with the stryker 955 can u turn the power down enuf to run an amp?
WSAC829
EN64ak
Why would you want to? The 955hpc+ already does 100 watts. Unless you have a high drive 500 watt or larger amp nobody will notice on the receiving end anyway. Also the Stryker would more than likely smoke a low drive linear that’s designed for 2-5 watts input, and if it does you risk ruining your radio also.
This will help explain how linear amps and RF power works in more in detail. Adding a linear amplifier! How Much Will It Increase My Signal?
Dirtblaster44
Minnesota
Also how wud you access the frequencies of 27405,27415,27505,27515,? And mine will come converted to 11 meter, I'm sorry I'm very new to this radio
