Stryker SR94HPC Help Wanted
N0YJV
Norfolk, NE
Hello,
I have a Stryker SR94HPC, and for now, I am just wanting to use the 11 meter part of the radio.
I have a programming cable and the Stryker software.
The trouble is that I am Visually Impaired, and I have contacted Stryker to see if they could send me a cheat-sheet of the buttons, because the hieroglyphics in the manuals don't work for the Visually Impaired.
But if I knew what each button does, like if you push it once or twice, etc., I could figure out how to set it.
I tried the software with my screenreader, and it is challenging at best.
I wonder if someone could fix my DAT file so it only does CB on high power.
I think I read where band D is the CB band, but I don't know which button gets me there.
But if all bands, A through J were CB, that would be okay, because I don't know which frequencies for 10 meter are commonly used, I have a license for Ham bands.
Thanks for any assistance, my email is:
glenn@ervin.email
prcguy
I have one and as a coincidence was just playing with it about an hour ago. I can try to make a cheat sheet but in my opinion its a very cumbersome radio to use even with good sight. The main knob defaults to a channel selector and you have to push a menu button just to turn up the volume then another to change squelch. I don't remember the sequence but there are multiple pages to the menu and the various functions you mention are on different pages and for me there is no good way to know what page I'm on without reaching for my reading glasses.
Hello,
glenn@ervin.email
N0YJV
Norfolk, NE
Hi,
Well anything would help.
I've figured out that button #1 toggles between FM and AM, and #4 briefly changes the volume.
I've heard nothing from Stryker on a cheat-sheet or any other assistance.
Glenn
N0YJV
Norfolk, NE
You are Visually Impaired the SR-94HPC is not the radio for
Hello,
All radios are digitally controlled any more, so if I want a newer radio, I'll have to have one that I can get set up so I can manage it with pushing certain buttons a certain number of times.
All I need is someone to give me the button layout and what happens with each push of any button.
Until manufacturers start including speech output, like Baofeng and Wulung has, I have to adapt, and if anyone is willing to assist, it will be much appreciated by many VI folks. I have the same challenge even with old radios, but at least I can count clicks on a dial and remember which buttons are for what, but again, to say a new type radio is not for me is wrong.
prcguy
As threatened, here is some menu info.
On the group of six buttons that surround the display the top left is P1, bottom left is P3, top right is P4 bottom right is P6.
On power up my radio has P1 for MOD, P2 for RFG, P3 for EMG, P4 for VOL, P5 for SQL and P6 for POW. On some menu items pressing the P button will toggle between selections and the far lower right FUNC knob will also change some selections within a menu item. For things like volume and RF gain the FUNC knob will change that value.
Press the far upper right button FUNC above the multi function knob once to get the next menu selections.
P1 for DSP, P2 for SCA, P3 for MEM, P4 for BND, P5 for DW and P6 for CAL.
Press the FUNC button again for another menu set.
P1 for NB, P2 for RB, P3 for HIC, P4 for TSQ, P5 for SPL, P6 for 5K.
If you press the FUNC button for another menu its only on screen for about 8 seconds before reverting to the first menu. You will have to look up some of the meanings of the selections as I've never used most of them. Good luck as this thing is a PIA even with good eyeballs and a magnifying glass.
N0YJV
Norfolk, NE
Hi there,
This is good, if I can find those values in the adulterated manual, after it was converted to TXT, I will be able to do a lot with this.
Thank you.
Glenn
