Hi
@bearcatrp, you could try a paperclip 📎 on your Uniden BCD160DN to see if that makes any difference. Try different lengths too. The shorter the better in many cases. Also, don’t forget about the built-in software attenuator on your scanner. That could help. Like has already been said, moving the scanner a few inches to find the “sweet spot” might improve things too. Another trick to try is by changing the antenna polarization from vertical to horizontal (lay your scanner on its back).
In my case with the Uniden BCD536HP, I have achieved decent reception in a heavily simulcast environment by reducing the antenna gain by 20dB or so 😂 and finding that sweet spot. I simply use inline attenuation that can be easily removed when I want to receive non-simulcast systems.
If you don’t have any inline attenuators with BNC type connectors on-hand, some examples would be:
Find Inline Attenuators and get Free Shipping on Most Orders Over $99 at DX Engineering!
www.dxengineering.com
ATT-20 Variable Attenuator
www.scannermaster.com
It is always fun to experiment with different methods in an attempt to overcome simulcast distortion…
<edit>
I just noticed that the Amazon link is NOT a set of attenuators (pictured) as I originally thought. It is for a single 20dB attenuator. Having a set of different values is helpful for experimentation. There are other attenuators on Amazon for $15 each. Shop around…
