Sudden Loss of Reception
emsflyer84
Central NH
It could be a mirror of a pager frequency you are getting, but could also be an overload issue but the 996 has a much better receiver than a 436 so are unlikely. On the frequency you have issues with to receive you make a Hold and then do Function+7 to enable IFX. It will change what mirror frequencies your receiving.
I always recommend to use a variable attenuator when using external antennas to more easy figure out whats going on. You gradually add attenuation to see how the signal you want to receive reacts and what the interference are doing. Scannermaster has one and you can also use the ones with F connectors if you get adapters or pigtails to go with it. With an overload issue the interference will be reduced much more than the wanted signal when slowly adding attenuation. You will also be able to listen to a weak signal and add attenution to see if the signal improves, that indicates overload, and you can leave that attenuation in place.
I would like to see scanners using several antenna inputs. As it is now all bandpass frequency bands are joined together using switch diodes to one common antenna connector. It would not cost much to have two or three antenna jacks and the switch diodes controlled to have each frequency or group/department/site directing a bandpass filter to a specific antenna connector.
/Ubbe
Thank you. I turned on global attenuation this morning and DID receive the signal I've been having trouble with but I haven't been able to listen long enough to see if it is consistent. I'll listen some more, then try to add attenuation to just the frequency I'm trying to receive and see what happens. Thanks.
emsflyer84
Central NH
/Ubbe
I believe pressing Func + 7 turns on ATT for that frequency, correct me if I'm wrong. Is IFX something different?
emsflyer84
Central NH
IFX might eliminate your issue (if it is mixing/image) without filters, but I will let those who have that make/model give you directions.
Thanks, just looking into this, I'll figure out how to try IFX on that specific frequency. Wonder if it's worth trying IFX AND the global ATT since that's seemed to help a bit.
merlin
DN32su
I am 1/2 mile from a very powerful rail base station. when they TX, all my VHF is gone.
I set up a 4 element Yagi toward the station and fed that 180 degrees out of phase to my discone.
VHF is back but still not perfect.
6 Db attenuator helps excep for very distant signals.
Ubbe
Stockholm, Sweden
I foolishly thought it was the same 7 on all Uniden scanners, but it is Fn+4 on the 996.
You shouldn't have to use Att at all on 996 if a 436 didn't overload, although it where using a smaller antenna.
/Ubbe
Ubbe
Stockholm, Sweden
Are you using a noise eliminator type of device that have an adjustable phase control? Try separating antennas as much as possible to make it cancel in as a small angle width as possible. You can also insert different lengths of small coax cables to one antenna to fine adjust the 180 angle for that specific frequency wavelength. Look at the signal strength of the rail base to adjust for minimum signal. The signal from both antennas from the rail base needs to be at as equal signal level as possible to eliminate it the most, but perhaps just reducing it to half might be sufficient.
/Ubbe
RoninJoliet
ILL
There has been a VHF band opening the last few days here in the Midwest , not sure if your area is included which may enhance your troubling frequency, you press F+4 for IFX on the frequencys in question,....
merlin
DN32su
/Ubbe
It is nothing fancy, the critical part is the tuned length of coax to a T connector. Up or down in frequency is a different phase shift so not so much 'bucking'.
This is the same technique I used on cable head ends to eliminate ghost.
It is effective enough reducing that unwanted signal by about 7 Db.
That base station is pumping no less than 150 watts to a super station master, I get about a +40 Db with no antenna connected.
emsflyer84
Central NH
Hey all, just curious about this because I'm in the process of trying to mitigate some strong pager signals that seem to be overloading my scanners when using my rooftop antenna. So, just curious more then anything.... the strong pager noise I'm hearing on 152.600 and 157.740 at my house in central NH, what is the noise I'm hearing? What are those signals used for? Video for reference. Thanks!
bob550
Albany County, NY
Using an SDR and free software such as PDW along with Virtual Audio Cable or VB Audio Cable, you too can decode this jibberish on your computer! Then you'll know exactly what pagers are used for these days. :) I periodically monitor 157.740 using PDW and VB Audio Cable. It's a mix of automated systems "phoning home" and medical facilities passing intradepartmental messages. From my QTH near Albany, NY, I pick up hospitals in southern Vermont. Since you consider this to be "interference", be thankful that pagers aren't being used with the frequency they used to be many years ago! You'd be tearing your hair out, LOL!
ecps92
Taxachusetts
did you confirm it is actually BOTH 152.600 and 157.7400 or just one of them??
I know in the prior thread(s) we suggested checking those two as they are the more Common VHF in your area.
emsflyer84
Central NH
Yes, confirmed, I think it was you who made the recommendation to check these, thanks for that. I even pick these up almost as strong using the rubber antenna on my handheld scanner driving around town. Very strong signals. See videos below.
Yep, because of the:
atrocious ERP's.
Some of these paging transmitters are running 300+ watts (transmitter x antenna gain) from very good locations.
They're trying to get a good signal way into the basement of the hospital, behind the Xray machine to a device with a little tiny antenna.
Your scanner doesn't stand a chance if you are close to these guys.
ecps92
Taxachusetts
let's back up a bit, are you 100% certain you are getting them BOTH at the identical time ??
Asking as these are two different Paging Carriers/Provider and which one did you match up to hearing in the background
when you are monitoring Conway PD
Asking as well as a 152 Filter is not the same as the 157 filter and you may only need one of them
emsflyer84
Central NH
Thanks, seems like everyone in the country would be having the issues I'm having! I think it's a combination of my rooftop antenna, my houses physical elevation on a hill with direct LOS to several towers around the area, the local hospital only a mile away, also with direct LOS to my antenna....
emsflyer84
Central NH
No, I have NOT been that scinetific yet. It just seems like both of those pager transmitters are basically always transmitting 24/7. I haven't matched them up with the noise I heard in the static on the Conway frequency.
