Sudden Loss of Reception
emsflyer84
Central NH
let's back up a bit, are you 100% certain you are getting them BOTH at the identical time ??
Asking as these are two different Paging Carriers/Provider and which one did you match up to hearing in the background
when you are monitoring Conway PD
Asking as well as a 152 Filter is not the same as the 157 filter and you may only need one of them
Regarding the Filters, PAR is making me one filter that is somehow going to address both frequencies, but you're right, I don't know which one is causing me issues, or if it's both. Anyway, he is making me a dual-stage filter that will target both frequencies. We'll see what happens. If that doesn't create enough of a "notch" for each frequency to help with my issues, the filter can be re-tuned so both stages are focused at only one offending frequency.
ecps92
Taxachusetts
Thanks, seems like everyone in the country would be having the issues I'm having! I think it's a combination of my rooftop antenna, my houses physical elevation on a hill with direct LOS to several towers around the area, the local hospital only a mile away, also with direct LOS to my antenna....
You are under 2mi from the Hospital which would be a common transmitter site for a paging vendor.
ecps92
Taxachusetts
time for me to bow out of these multiple threads for the same issue, as you can't fix something till you know where the actual offender (freq) is
emsflyer84
Central NH
Yes, I'm on a bit of a hill and there is a valley between me and the hospital, so we are basically LOS between us. I can't seem to find what paging system or frequencies they might be using at that particular hospital though...
emsflyer84
Central NH
No problem, thanks for your input. This thread was only meant as a curiosity for me regarding what the pager transmitters were actually used for.
ecps92
Taxachusetts
(i know I should just hang it up) you need to listen to the Conway Channel and then on a second radio determine which of the two possible frequencies is the offender -yes these page out a lot, but there is down time, so nailing it down is cruicial)
emsflyer84
Central NH
Will try to do this and see what happens. Thanks.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
Yep, because of the:
Some of these paging transmitters are running 300+ watts (transmitter x antenna gain) from very good locations.
They're trying to get a good signal way into the basement of the hospital, behind the Xray machine to a device with a little tiny antenna.
Your scanner doesn't stand a chance if you are close to these guys.
Several of them near me have a 1 kW ERP.
davidgcet
when we had our vhf paging system we had ERP close to or over 3000 watts at main towers and 1000 at hospital sites. either one at your range will easily overload you. heck i could watch our modulation on a couple of tv channels when the cable was still analog around here. it put wavy vertical lines in the picture that almost looked exactly like the horizontal mod line on the service monitor. bad thing was the worst channel was the one The Weather Channel was on and was our busiest carrier that during the day rarely unkeyed for more than a second at a time.
John_S
Saratoga Springs, NY
I found a list of all the pager VHF and UHF frequencies and programmed them into a spare scanner and let it go. I didn't even need the antenna plugged in to get 157.740 making a racket. That and all the data links around 454 mHz. It's a wonder I can get anything on the scanner at all.
chrismol1
P25 TruCking!
in saratoga springs you will get slammed on 157.74. that is local high power paging and also used for the area hospital pagers. The 454s is the trunked DMR system putting out good power as well.
emsflyer84
Central NH
Hey all, rehashing an old topic here one more time just to see if maybe there is some fresh insight. I've got a two-scanner setup at my house for a couple Broadcastify feeds I maintain. They are fed by a rooftop antenna which is a good location at my house with long lines of site in all directions and pretty good elevation.
Something seems to be knocking down my reception as I can't get a couple frequencies that I CAN get when I'm down at ground level in my car with a mobile antenna. I believe it's a very strong pager signal or something similar, possibly from the hospital nearby. I say this because on some of the weaker frequencies I can hear the pager noise in the background sometimes. Also, on the rare occasion that my reception is NOT being affected by this, I can pick up more stuff, farther way with much stronger signals. During those times I've manually tuned my scanner to the pager frequencies and I don't hear them. This hasn't happened in a while though, the pager signal has been consistent, 24/7.
I've tried the following:
- Different antenna's at different heights
- Different types of coax (LMR400 vs RG6, etc)
- Attenuation settings in my scanners
- In-line adjustable attenuator
- PAR filters for the specific pager frequencies
None of these things have made any difference. Before I just resort to the fact that I'll need to live with hampered reception, I just want to see if there is anything else I can try, or any other ideas out there or equipment to try to help mitigate this problem.
Now, I'm still not 100% sure it's these pager signals that are causing the problem. But everything I've been able to test has pointed that way.
Thanks in advance for reading and for all the great info on these forums. Of course questions are welcome.
tvengr
Well Known Member
Baltimore County, MD
I had a similar problem with scanners in our newsroom. We got a tunable notch filter. I tuned it to the pager frequency and put it in the antenna line. Problem solved!
emsflyer84
Central NH
Thanks, I’ve tried pre-tuned notch filters with no luck, can you give me an idea of what filters you used? And how you determined what frequency was the problem?
ecps92
Taxachusetts
You need to listen/search with a 2nd radio to find the similar interference occurring to nail down the culprit
