Summit County, Ohio and Richfield TRS
Ohio
I take it that the Ritchfield TRS has been absored into the Summit County, Ohio simulcast TRS? If I was able to recieve Ritchfield, is it safe to assume that I can receive the Summit County, Ohio simulcast TRS?
mszabo2000
Rootstown, Oh
The Richfield analog system is not part of the Summit system. However, there is a Summit site on the same tower so you should be able to hear the Summit system.
Nasby
Ohio
Depends on your location and the type of scanner you have.
Summit Co. is a simulcast system which can give older scanner fits (depending on location). But if you are in a "sweet spot" you will be able to hear Richfield PD / FD.
Ohio
Thanks.
