Sumpter County Ga.
ke4crc
Lakeland, Fla.
My brother has a business in Americus and I was wondering which freq to lessen too.
what confuses me is the dispatch being in another county.
Are they using a TRS system or a Conventional system?
I found 3 TRS for Sumpter County in the FCC database. WRXL 605
YW - Public Safety Pool, Trunked FB8 - Centralized Trunk Relay NXDN
151.0025 151.355 154.055 154.3325 in Americus
151.0175 151.4825 159.2025 159.465 Leslie
151.1075 151.250 159.0975 159.1725 Plains
I didn't see these freq. in the RR database
tnx
kg4ojj
Crisp County, GA, USA
That's a new system (for Sumter County, not Sumpter); it's not online, yet. County Commissioners voted for an upgrade.
The Sheriff, County Fire, and the City of Leslie FD/PD are NXDN conventional but encrypted. Americus PD is also encrypted; on 700 MHz conventional.
Come to Americus and you get to only listen to the Americus Fire department on P25, State Patrol on P25, and Goldstar EMS on analog.
ke4crc
Lakeland, Fla.
thanks for the info.
What system does the GSP use in Americus I've heard them on VHF p25 in Cordele & I thought I heard GSP on the crisp P25 system .
kg4ojj
GSP Post-10 (in Troop G) is Americus. Conventional P25 VHF in Americus. In the clear, not streamed.
What you hear in Cordele is a patch into the Crisp County TRS. The Cordele Post is also VHF P25 conventional (out of Troop H).
Americus PD/FD are on four conventional P25 repeaters in the 770MHz range. Each agency has a dispatch and tac channel; the city has 700-CALL-50 and 700-TAC-51 repeaters. APD is encrypted, as mentioned above.
Likely what you found in the FCC database will be a three-site NXDN (4800 baud; very narrow) trunking system. I've only heard one of the frequencies pop-up, but I think it was during VHF skip due to Hurricane Idalia.
[edited to add] Sumter County is part of the consolidated dispatch center out of Ellaville. Not sure how they tie-in on local repeaters, but they are usually referred to as "Central" over the air.
millam
Old Radio Guy
I think this is relevant to this thread. I am in Houston county Alabama and can see this
system when skip is running. Thought I would post it and see if it was of any use. If
it is in the wrong place just disregard.
Mil
WRXL605
Locations
Frequencies
Map:
Network: L533
3 Sites
Site 1 NDXN 48 RAN 1 I haven't verified except for the CC.
CH Freq
1 151.0025
2 151.3550 CC
3 154.0550
4 154.3325
Site 3 NDXN 48 RAN 2
CH Freq
5 151.0175
6 151.4825 CC
7 159.2025
8 159.4650
Site 5 NDXN 48 RAN 3
Ch Freq
9 151.1075
10 151.2500 CC
11 159.1725
12 159.0975
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Mil
WRXL605
Locations
Frequencies
Map:
Network: L533
3 Sites
CH Freq
1 151.0025
2 151.3550 CC
3 154.0550
4 154.3325
CH Freq
5 151.0175
6 151.4825 CC
7 159.2025
8 159.4650
Ch Freq
9 151.1075
10 151.2500 CC
11 159.1725
12 159.0975
I have access to a remote monitoring station in Bulloch Co GA. Last night I picked up all of those sites, tracked things. Despite it rarely happening, they set the sites up pretty much like you woudl see it in FCC records (so your guesses are correct on the non-CC channels).
This has been submitted to the database. You really should have submitted back when you discovered it.
SO is on TG 101. There was some traffic on TG 201 but I'm not sure what it is.
Might take a few days for an admin to work my submission, but I would guess that by the end of the week this system will be in the DB for Sumpter
It's network L535 by the way, not 533.
Mike
RRR
OFFLINE
USA
Where again is Sumpter county? 😗
RRR
OFFLINE
USA
(B)
Living life to the fullest
joejo95
Russell Co. Ala.
I am hearing Talk Group 201 being called Sumter Fire. Also hearing and shows Sumter GSP on UID 1030 in ProScan logs on TG 101.
mtindor
FMP24 PRO USER
What site (or sites) are you tracking? And are you feeling that you are getting all converations? I believe the information that @millam originally posted is correct, as that is what I determined when I copied those systems via a tropo ducting event recently. That system has been submitted to the DB, so it should be in the DB soon. But if any of the site's channel orders are off (causing missing transmissions), please do report it. Unfortunately, if that were to be the case, probably only you or somebody else within earshot of the system could figure out the correct order. But from what I could tell, when I was copying each site, voice seemed to track just fine.
Mike
joejo95
Russell Co. Ala.
I am only getting Site 5 and best I can tell the LCNs and RAN are right. Also I do believe he got all the freqs right. I ran the Analyze on my scanner, 436, on Site 5 and it matchs up with Millam info.
mtindor
FMP24 PRO USER
Ok good deal. Thanks for reporting on that!
mike
Starcom21
IL /MO/Global DB Adm!n
Locals, can we check to see if the conventional NXDN is still in use? 154.875 Sheriff and 155.3175 Fire
Leslie still using 151.19 NXDN Fire?
A whole lot of frequencies on the page are expired or have no tone listed.
joejo95
Russell Co. Ala.
I will try and see but I get these systems when the skip is good usually at night but not always every night.
RRR
OFFLINE
USA
Wow.. It was even put into the database as “Sumpter” 😂
RRR
OFFLINE
USA
You’re aware. Y’all got this 👍🏻
ke4crc
Lakeland, Fla.
I was playing on DSD one day and found 152.2925 after searching I found the following info
IG - Industrial/Business Pool, Conventional
SUMTER ELECTRIC MEMBERSHIP CORPORATION
AMERICUS, GA 31709
KIA 424
Color Code 1
152.2925 FB2
152.3525 FB2
152.4575 FB2
153.590 FB
153.695 FB
I'm hoping you can interpret the dsd info below for me
DCC=1 LRRP; Tgt=64250 Src=142
DCC=1 LRRP; Tgt=64250 Src=731
DCC=1 LRRP; Tgt=64250 Src=1107
DCC=1 LRRP; Tgt=64250 Src=125
DCC=1 LRRP; Tgt=64250 Src=1112
DCC=1 LRRP; Tgt=64250 Src=143
DCC=1 LRRP; Tgt=64250 Src=120
DCC=1 LRRP; Tgt=64250 Src=1119
DCC=1 LRRP; Tgt=64250 Src=137
DCC=1 LRRP; Tgt=64250 Src=81
DCC=1 LRRP; Tgt=64250 Src=100
DCC=1 LRRP; Tgt=64250 Src=1108
DCC=1 LRRP; Tgt=64250 Src=1116
DCC=1 ARS; Tgt=125 Src=64250
DCC=1 ARS; Tgt=1001 Src=64250
DCC=1 LRRP; Tgt=1001 Src=64250
