- Joined
- Nov 9, 2011
- Messages
- 0
SUSUMU
GNN COMPONENTS CO., LTD
1. Introduction :
SUSUMU International U.S.A., Inc. is a sales and marketing arm of The SUSUMUCompany, the world’s leading specialist in thin film components for over 40 years. The SUSUMU line of products includes highly reliable thin film resistors with an extremely low failure rate for severe environments. SUSUMU’s miniature low resistance value current sensing chip resistors feature the highest power rating in the industry, excellent performance in resistance tolerance, noise, long term stability, and heat dissipation.
2. Product Line :
Susumu | Speakers & Transducers (1)
Susumu | Attenuators (25)
Susumu | Capacitor Kits (2)
Susumu | Current Sense Resistors - SMD (1031)
Susumu | Inductor Kits & Accessories (2)
Susumu | Metal Foil Resistors - SMD (285)
Susumu | Power Inductors (69)
Susumu | Resistor Kits (11)
Susumu | Resistor Networks & Arrays (1)
Susumu | Thin Film Resistors - SMD (30040)
Susumu | Delay Lines / Timing Elements (163)
3. Featured of product :
Susumu KRL Series Precision Current Sensing Resistors
The Susumu KRL Series Precision Current Sensing Resistors extend the resistance range from the existing RL / PRL series down to 1mΩ. The KRL series has improved TCR that is as low as ±50 ppm/ºC and is available in two geometries - longer side and shorter side terminal type - ranging from 1/3W to 5W power rating. Also available are types for high temperature applications (up to 170ºC) and for low thermal emf applications. TheSusumu KRL Series Precision Current Sensing Resistors offer a face down mounting for accurate sensing. RoHS compliant, the protective coating is halogen-free.
Susumu PRL Series Current Sense Resistors
The Susumu PRL Series Current Sense Resistors are very low resistance value chipresistors with long-side electrodes for high-precision current detection. Featuring excellent performance in resistance tolerance, noise, long term stability, and heat dissipation, the PRL series is useful in many current sensing applications. The Susumu miniature PRL series Current Sense Resistors are offered in 1/3, 2/3, 1, and 2-watt power handling thin film resistors (PRL1632 are realized as 1W for 3.2x1.6mm [1206]).
Susumu RG Series Ultra Precision Thin Film Chip Resistors
The Susumu RG Series Ultra Precision Thin Film Chip Resistors feature high reliability and excellent stability at different environmental conditions with resistance tolerances from ±0.02% to ±0.5%. With low noise, THIN FILM (NiCr) construction, the RG series is ideal for automotive, test and measurement, optical, telecommunication, medical, and industrial equipment.
1. Introduction :
2. Product Line :
