SWL Loop antenna spacing.
KJ5HMI
Hello, I need a little advice on loop antenna spacing. I presently have a MLA 30+ loop antenna installed about 7 foot off the ground. I have purchased a K-480 WLA loop antenna and want advice on the spacing needed between the antenna’s so there is no interference between them. These are used for receive only. Thanks in advance on any advice I may receive.
pjxii
Naples Florida USA
I don't have either of those and apparently no one here has tried to do what you're planning. Idk about loops specifically but I was looking up info on straight wires and the distance to avoid interacting between them for HF receiving only. What I read said it's minimal even if relatively close so I will be experimenting. Let us know how things work out for you, I would like to know your results.
