System 104 (DMR)
DaveH
Ottawa, Ont.
Perhaps someone could check accuracy for this system, based on what I have received:
(1) 423.3375 and 423.525 are on Site 5. DB lists on Site 3.
Appears to be:
TAFL Search Results
(2) 420.150 and 422.2125 are on Site 7. DB lists on Site 3.
Appears to be:
TAFL Search Results
(3) Site 3 has 25 frequencies listed, is this accurate?
(4) Sites found as Neighbours but not in the DB include: 2,6,7,9,10,11,12 .
Dave
EricCottrell
Boston, Ma
Hello,
I was in Longueuil over the weekend with a SDS100 scanner, so I was only able to get Color Codes and System IDs. I got two frequencies with the 104 System ID. This appears to be a CTM system.
462.0750 Color Code 3 Control Channel
TAFL Results
463.5250 Color Code 3 Voice Talkgroup 11148
TAFL Results
I have no indication that the two frequencies are part of the same site. I have gotten transmissions from both Place Ville-Marie and St-Bruno in the past, so they are within range of the location.
73 Eric
DaveH
Ottawa, Ont.
https://www.radioreference.com/apps/db/?sid=8043
Some sites show duplicated frequencies. Others do not, which is not consistent.
Also, Colour Code (DCC) and Neighbour lists are missing for some sites. I recommend that
someone close to the action runs DSD+ software (free), which easily provides these details.
If data has been taken directly from scanner, and from IC (TAFL) database, it is usually
not complete.
I have been able to receive a few sites when conditions are good, Colour Code=3 for these.
Dave
