Tait T2030 programming
Spider255
A bit of a long shot...
I don't suppose anybody knows how to program 4 conventional channels into a Series 2 Tait T2030 Trunked radio?
It can be done but its just a question of knowing how. I've tried adding the 4 conventional channel with frequencies but the radio doesn't do any thing because its still in trunked mode. I've used up all my T2010 conventional boards and the only thing I have is T2010 firmware but I don't know how to flash that to the radio.
The best way would be to program the Tait T2030 with 4 conventional channels in the Trunked Tait application... if anybody knows how it would save me having to hunt for another T2010 board.
Thanks.
Spider255
OK I take it nobody knows....
Maybe this question might be easier....
If anybody knows how to program a conventional channel into a trunked radio "any radio" I read something about the channel needing to be added to a trunking network... I don't understand trunking so if there is any life out there and you know about how to add conventional channels to a trunked system then please let me know.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I don't recall exactly how the Tait programming is laid out, but I suspect that you wouldn't add a conventional channel to the existing trunking programming. Rather, I would think that any conventional channels should be in a separate system/personality, which you likely need to create in the CPS if one doesn't already exist.
If you can't seem to make ANY changes to the programming, it could be that the radio will not allow programming changes without a system key for that particular trunking system being present.
...just some possibilities to chew on.
Spider255
Thanks for the info much appreciated. I think you maybe right that Conventional channels can't be added either that or I need to put the 4 conventional channels in another part of the CPS. I try and make a bit more sense of it but if I get nowhere with it, the good news is that I can upgrade the firmware that will allow Conventional mode although a lot more harder to do that way.
