Tait TP8100 Bricked
Jacksonechols55
Define "bricked". Was it on a trunked system?
No trunked system. I believe it was messed up during FW updates. Radio is displaying system error S 40. Radio will not do anything other than display that. Will not read or write.
KevinC
Encryption
I'm everywhere Focker!
Ok. I was thinking maybe it was inhibited if on a trunked system. I can't help otherwise, sorry.
Echo4Thirty
Spring,TX
The typical procedure for a firmware update on a Tait is to read the tuning file and save it, read the codeplug and save it. Then update the firmware, then write the tuning file and then the saved codeplug.
If none of that works, then the only thing you can do is send it to Tait via a dealer. That said, the radio isnt worth what the flat rate repair would be.
SVR-TAM-FPR-TP8Repair TAM TP8 Portable
350.00​
Jacksonechols55
350.00​
So it only displays system error S 40 and will not read or write, assuming with that it's toast? I haven't tried updating firmware it was like this when I received it.
Echo4Thirty
Spring,TX
yeah, even when they are in a goofy error state, there are still comms. If you cannot get anything out of it, id say its toast.
Echo4Thirty
Spring,TX
No worries, I have two at Tait right now that bricked during a conversion from trunked to conventional. Crossing my fingers they fix them since they were bricked using their ECC codes.
