Tait TP9800 multiband
joehumberger
I understand that Tait announced today in a dealer webinar that they are releasing a software upgrade that can be purchased for existing and new TP9800 and TP9900 radios that will enable Front Panel Programming (FPP).
This is part of their new feature set that is being released with the new TP9800 aimed at Wild Fires
"I understand that Tait announced today in a dealer webinar that they are releasing a software upgrade that can be purchased for existing and new TP9800 and TP9900 radios that will enable Front Panel Programming (FPP)." -> This is true. Was announced to us dealers this past week. We have more information about the Wildland Fire radio on our website at Tait Radio | Your Critical Communications Partner | New Orleans, LA - ComJoT LLC
BigLebowski
Piedmont NC
Anyone observed a sudden issue with the TP9800 where their volume is at max level regardless of the volume knob position? Radio was fine last week, sat over the weekend, and when powered up today the issue was present. I've stepped the firmware up from 3.00.04 to 3.01.02 and now 3.03.08 and the issue persists.
BigLebowski
Piedmont NC
Does using a speaker mic change anything?
Same behavior with a TSM4 speaker mic.
EDIT: To add, in addition to bumping the firmware I have reloaded the programming file, reloaded the saved calibration file, and loaded a saved programming file from weeks ago and the issue persists.
otobmark
NC
You are kind of down to failed encoder or it’s circuit. You probably already did this but open squelch or tune in weather broadcast so as to have continuous audio while you play with volume knob. No change or glitches will prove nothing but any effect from playing with knob will give evidence to failed encoder. Like you I hope it’s firmware or software but it’s looking like hardware since failure happened independent of any programming changes. Tait NZ will probably be interested in talking to you directly if you reach out.
BigLebowski
Piedmont NC
I’ve had a lot of issues with the software, mysterious issues that they can’t seem to duplicate but they have been pretty responsive so far.
otobmark
NC
Trying hard not to make ridiculous wild guesses…all too common on forums…
Probably no info on how to do a hard reset— might wipe your installed options anyway. If radio does a soft power down normally then maybe leave radio on and pull battery to cycle power.
Beyond that check your Bluetooth and cycle through the settings in addition to just turning it off. Bluetooth competes for your radios audio and would be one place where buggy code might get lost. Do you have a BT earpiece that will pair with your radio? If so see if it works correctly. I have success with old wrap around the ear with small mic boom Plantronics units on all of my BT radios. I don’t suspect Wi-Fi but heck play with it if the mood strikes you.
aglowgibbon
Canton, Texas
Are they going to implement any kind of non-affiliate scanning? I heard that being rummored at one point, but nothing concrete.
