casesoccer12 said:
What is the "talkaround" frequency or talkgroup ID. i agian heard zfd using this what is it??????
Talkaround has several meanings. As does TAC
T Talk
A Around
C Channel
But TAC could also be short for Tactical channel.
It does generally mean “talkaround” the repeater. That means usually close in radio traffic of less than 1-2 miles. It means nothing is going through the repeater and usually not being recorded or monitored by dispatch.
It could mean a separate simplex or repeater channel specifically for non-essential or operations type radio traffic.
Some times it’s as simple as flipping a switch which makes that radio transmit on the repeater output channel. So it could be several things depending on how the radios are programmed, channels available, or it could be on a talkgroup within a trunked system.
My radios have both a separate talkaround channel, and a switch to make the repeater out channels a simplex channels instead going through the repeater. Hope this helps.
AL
