SDRTrunk Talkgroup log on SDRTrunk?
Mex
Surrounded by cornfields
Hello,
I got SDRTrunk running on a local P25P1 system searching for new talkgroups. Is there a log or something of seen talk groups. It'd be a lot easier to let for a few days and come back and check out if it caught anything worthwhile.
thanks in advance
maus92
OCMD
There is a logging function, but it must be enabled. The location of the log files also differs depending on your OS version. You can enable logging in the Windows version once you start monitoring your system.
hruskacha
Muskegon
The "Call Event" Logs import VERY WELL into Excel! It is much more helpful to combine log files using a text combining utility beforehand though to import multiple logs as one sheet.
Mex
I just found out about unitrunker so I'm letting that do logging on my primary PC cause I"ve been having issues on the SDRtrunk PC. But the SDRTrunk log is very informative also.
