Tanker Truck Fire on 880 in Oakland
scannerboy02
Incident: 0235 Type: Traffic Collision - Ambulance Responding Location: SB I880 JSO 5TH AV ThomasBrothers: 649 6H info as of: 10/22/2008 7:10:38 AM
ADDITIONAL DETAILS
7:12AM NB AT 23RD OFR TO ASC WHAT THE CLOSURE IS
7:09AM 25-74 ON BRZ / WILL LOOK FOR OPD / ON N END OF FIRE
7:09AM NRC WILL 1039 ANY/ALL NECESSARY AGENCIES
7:09AM CG REQ SOMONE IN CHARGE 1097 CALL NRC (NAT L RESP CENTER) @ 1-800-424-8802
7:09AM 1039 SF CG PETTY OFCR HENRY LINE 102
7:09AM CITZ ON 911 LINE REQ CHP RESP TO JACKSON TO DIVERT THE TRAFFIC OFF THERE - ADV CITZ CHP STILL 106 AT SCENE
7:05AM OAK FIRE INQ IF ANY EMERG VEHS ARE ABLE TO ACCESS FROM ANY OF THE RAMPS ON NB SIDE
7:04AM 1039 DOTCC W/LINE 102
7:04AM 1039 PGE - MARCUS
7:00AM 1039 AT&T
7:00AM COPY LINE 98/1039 DOTCC
6:59AM HAVE DOT 1023 ON CLOSURE- SUPERVISOR 1097
6:58AM THE ENRTIRE FWY SHUT DOWN AT BOTH DIR - TAKING VEH S OFF AT EMBARC SB
6:58AM PER 8M ADV NEED TO CLOSE EB 80 FRM BRG
6:57AM 3 POLES BURNING AT MAX
6:57AM 96-8M COULD RUN BREAK - CONFIRM CALTRANS IS 1097 AT LINE 86
6:55AM **PLS ADV IF ANY UNITS WILL BE ENROUTE TO CLOSE WB 80 TO SB 880-
6:53AM RE LINE 80 - S3 ADV NO VEHS ON NB SIDE
6:53AM PER S3 - COMMAND POST ON EMBARC JUST ADJ TO FIRE LOCATION JSO EXECUTIVE INN
6:50AM WILL ALLOW BIG RIGS ON 580
6:47AM 1039 LINE 39 - VM ONLY FOR CAROLOS SANCHES OF NRC ENVIRONMENTAL
6:41AM 1039 OES//# 08-7614
6:38AM 1039 MARIN OFC / PER 34-S20 / NEG 1014
6:38AM SO FAR 2 VEHS INV - NEG INJ
6:38AM **SIG ALERT UPDATE** TRUCKS ARE ALLOWED TO USE 580 FOR THE DURATION OF THIS INCIDENT REFER TO LOG 235
6:37AM WILL CALL WHEN CLOSE TO SCENE
6:37AM PARTY LINE 39 EB 580 AT SAN RAFAEL BRIDGE-OFF LL NOW
6:35AM PER CH2 -8600 GALS IN TANKER
6:34AM PER 24M - OUT WITH DRVR - IT IS GASOLINE IN TANKER
6:34AM REQ 1014 SB 101 JNO 580 NOW STILL ROLLING
6:34AM FIRE 1097 / TRYING TO PUT OUT FIRE/ UNABLE TO DETERMINE WHAT IS IN TANKER AS OF YET
6:34AM FIRE 1097 TRYING TO PUT OUT FIRE NOW - UNABLE TO TELL WHAT TYPE OF TANKER
6:33AM S3 REQ UNITS GOING 1097 TO ADVS WHAT KIND OF TANKER AND CONTENTS /BC BY POS 7
6:32AM **SIG ALERT UPDATE** N/B 880 IS ALSO AFFECTED BY THE FIRE TRAFFIC SHOULD USE 580 TO AVOID THE AREA
6:32AM TANKER FULLY ENGULF IN FLAMES
6:31AM ARE BIG RIGS GONNA BE ALLOWED TO USE I580 AS ALTERNATE ROUTE
6:30AM PER S3 INQ W FIRE IF ANY INFO ON WHAT WAS IN TANKER
6:27AM 1039 DOTCC
6:24AM 1039 FIRE TO LINE 19
6:23AM ADV FIRE TO TAKE EMBARCADERO
6:23AM ***SIG ALERT***SB 880 AT 16TH ALL LANES BLOCKED BY COLLISION AND VEHICLE FIRE USE ALTERNATE ROUTE REFER TO LOG 235
6:22AM SB 880 AT 16TH PER OPD, OPD 1097 SHUTTING DOWN SB TRAFFIC NOW
6:22AM OPD 1097
6:21AM S3 REQ SIG ALERT
6:19AM VEH IN CD EXPLODED
6:17AM 1039 1141
6:17AM ONE VEH INTO CD / BIG RIG HIT IT/IN FLAMES NOW
6:17AM 5 VEH TC
RESPONDING OFFICERS STATUS
6:23AM CHP Unit On Scene
6:31AM CHP Unit On Scene
6:32AM CHP Unit On Scene
6:35AM CHP Unit On Scene
6:36AM CHP Unit On Scene
6:39AM CHP Unit On Scene
6:49AM CHP Unit Assigned
6:51AM CHP Unit Enroute
7:03AM CHP Unit Enroute
7:07AM CHP Unit Assigned
7:15AM CHP Unit Enroute
scannerboy02
OAKLAND, Calif. (AP) - Traffic on Interstate 880 through Oakland
is expected to be jammed throughout the morning after a crash
involving a gasoline tanker truck and a car.
Both sides of the freeway are closed near downtown Oakland after
a crash a little after 6:00 this morning involving the big rig and
a car.
The impact from the crash ignited the 8,600 gallons of gas being
hauled by the truck, sending flames high into the air.
Firefighters using foam were able to put the fire out after a
little more than an hour.
Police say the truck driver was able to escape the crash unhurt.
No other injuries were reported.
omigoat
Benicia, CA
At least this incident will only require a stretch of repaving which might be completed by tomorrow instead replacing an entire overcrossing. Made for some interesting Oakland CHP traffic this morning.
EDIT: Fortunately, the damage to the roadway surface wasn't an extensive as it could have been and CALTRANS had all lanes of southbound 880 repaved and open by this evening.
