KB2GOM
I sent the following to Kaito corporation, and while I am waiting for a reply, perhaps some of the folks here can shed some light on these questions.
"I just purchased a Tecsun pl-880, and so far I am very well pleased with it. I use it primarily for listening to shortwave and utility stations on the HF bands.
I have some questions regarding powering the PL-880.
1. It comes supplied with a 18650 Li-ion battery that is labeled 3.7V, 2000mah, 7.4Wh.
Can I use any 18650 battery to power this radio? If I use one that is labeled 5000mah, will it last longer?
2. The radio does not appear to receive signals while the battery is charging. Is that correct?
3. What do you recommend for operating the radio during an emergency when charging power may not be available? Spare charged-up batteries?
4. I have a power supply for another SW radio (a CCrane Skywave SSB) that terminates in a mini-USB plug. It is labeled output 5v, 300mA. There is a diagram that shows the end view of the plug with "+" on the left and "-" on the right. Can I use this for recharging the battery?"
