ET-NL
On the the private call's I now also see the ISSI of the mobile unit. With the previous versions of Telive I only saw the ISSI of the office unit.thanks for the report!
do you get more SSI info for calls in the new version?
ET
I prefer my previous method . In GRC you have to search for the right signal wich is often boring . With QTHID , you put the exact frequency and Tetra decoder is running .
I succeed in 1.8 with SDRPLAY by using my own osmosdr-tetra_demod_fft.py .It is working fine also with RTL SDR KEY
I tried 1.8 with funcube pro plus and GRC changing in grc frequency and hardware hw:2 to hw : 0 but can't decode . I found hw is 1 but grc is in 96k and I should de 192K for funcube pro plus
Is that 2 software have the same function to decode the tetra?
I never succeed with GRC ,
It is too boring trying to set the exact frequeny with GUI .
Proud to announce that I have just got the following working:
0. gnuradio-3.7.9
1. receiving data from an osmosdr source directly on the RPi2 (rtl-tcp)
2. getting it to work with Gnuradio-Companion on the host system
3. compiling the grc script modify it to run headless on the RPi2
4. running grc headless on the pi with direct hardware access (hence not using rtl-tcp)
5. running telive on the Rasberry Pi
6. encoding sound with opus
7. broadcasting metadata & voice to zeromq
Load average: 1.71, 1.79, 1.65 [verbose messages off in telive]
Indication of the cpu usage across the different components;
Code:root 16485 71.0 7.0 204992 66796 pts/3 Sl+ 23:33 16:34 python2 top_block.py root 16491 12.8 7.2 221248 68912 pts/1 Sl+ 23:33 3:00 python demod/python-3.7/simdemod2.py -o /dev/stdout -i /tmp/fifo1 root 16492 17.2 0.1 2856 1624 pts/1 R+ 23:33 4:01 ./tetra-rx -a -i /dev/stdin root 16581 11.2 0.6 25520 6080 pts/5 Sl+ 23:41 1:47 ./telive
If people are interested I am happy to write up an in depth tutorial on this specific project. But I want to focus on the bigger picture
For now a small picture
Hi skinkie, I tested the installation with automatic script raspbian (did not work), in lubuntu, and ubuntu mate. In the last two, it works properly until it starts to decode voice, at which spend 4 or 5 seconds and the Xterm window ./rxx process stays blocked.
As you've accomplished it work? Thanks in advance
I didn't understand what is the best between grc with UDP or GRC with fifo .
I noticed that rxx is changing to all knows tetra frequencies in my 425 -430 Mhz range . rxx is swiching to another frequency after displaying AFC series then synchronize to another frequency and decode again
What rxx dont respect the frequency I put in grc ?
