Tetra decoding
giannit
are now to work, control as soon as I can to check. thank you. still gqrx, do not know well Linux, then chroot and for me unknown, someone has developed for example, even just sdrsharp or other side of telive without compromising telive? and if you how? hraxie yet.
mescalero
Greetings to me too need help (PM)
Maurizio
LimaZulu
I'm stuck on step 2 - installing gnu radio 3.6. The script ends with the following error
Fetching various packages (Gnu Radio, UHD, gr-osmosdr, gr-iqbal, etc)
via the Internet
=======> THIS MAY TAKE QUITE SOME TIME <=========
Fetching Gnu Radio via GIT...Done
Fetching UHD via GIT...GIT checkout of UHD FAILED
If you have found this script useful and time-saving, consider a
donation to help me keep build-gnuradio, simple_ra, SIDsuite,
meteor_detector, simple_fm_rcv, and multimode maintained and up to date.
A simple paypal transfer to mleech@ripnet.com is all you need to do.
Send success/fail info to sbrac.org?y
Any idea? Debian 7.7 here.
giannit
I actually occurred Air encryption 1 , then Tetrapol guess. This is not possible to decode or mistaken .
sq5bpf
probably something wrong with accessing the repository on github (maybe a firewall blocking it?). please check if this works now.
look at the build-gnuradio script - it is a very straightforward shell script, so should be easy to understand and debug. and also search the internet for answers, the build-gnuradio script from SBRAC is used by thousands of people around the world, and you should be able to find a solution to your problem.
yo4tnv
KN35OQ
Unfortunately none of those 5 or 6 signals here on my QTH are unencrypted. All of them carry the same MCC/MNC. I will leave it working for a while in a work day, to see if i catch something in my fishnet.. I am thinking of a sh script to launch all tools at once in the proper order.
Also thinking of an supplementary block in GRC to FM demod the signal and hear the buzz, for audible bias based on signal intensity.
sq5bpf
enable recording (and mutessi, although that can skip some traffic) , and leave it on for at least a week. if you have enough cpu, then you can decode all channels simultaneusly. i've recently commited 3, 5 and 6 channel receivers to the telive github repository, so you can use only one dongle for all channels if they fit within the dongle bandwidth
please don't publish :)
this will make people try to use the software without reading the documentation first, and as a result ask stupid questions later (look at questions in dsd topics on this forum for a quick sample)
this is easy, but won't get you any advantage (and will result in more cpu use), the spectrum display is much better for this.
yo4tnv
KN35OQ
I saw that
Of course
I have enought cpu on A6/quad APU, but i will move the setup on my tiny home server (Mini-ITX Atom 330/64bit capable) to leave it rolling for long time/less power consumption. Also i have two dongles (bought second one for unitrunker sport) and i will try to put them both to work.
yo4tnv
KN35OQ
in the ets-codecs package, is there amr-codec needed or only c-code?
My ./rxx tetra monitor is pretty empty, from time to time showing PLAY on red and OK on white. Is there a legend for that?
I know, I know.. I`ll read the docs.. :)
yo4tnv
KN35OQ
I do receive garbled sound from time to time. Is there a codec problem? please help
sq5bpf
if the files with garbled audio are all called traffic_xxx_yyy_0_0_0.ogg, then enable mutessi
sq5bpf
c-code only
http://www.tandcca.com/about/page/12029
"Adaptive Multiple Rate (AMR) Voice Codec
The AMR codec, operating in the 4.75 kbits/s only mode, has been chosen for possible future applications in TETRA. However, completion of the Air Interface Standard to accommodate the AMR codec is suspended in TC TETRA until sufficient market need is identified"
OK - i got some recent traffic on this usage identifier
PLAY - i am playing this audio now (this will show sometimes even with encrypted audio unfortunately)
for now this is not in the docs, will fix that in the future
EDIT: actually this was in the docs :) so no fix necssesary
sq5bpf
if you see any output from tetra-rx (receiver1 script etc..), then this is tetra.
tetrapol is something completly different, the only similarity is the first 5 letters of the name :)
giannit
On some frequencies feel perfect audio, on the other, where the air crypto 1 audio is inconprensibile. This leads me to think that it is Tetrapol or that other kind of crypto may be used in combination with tetra?
sq5bpf
enable mutessi. also it may be that these networks with encryption turned on carry only encrypted traffic, and you will never hear anything on them
i'm happy to hear that you have perfect audio on unencrypted ones.
this is not tetrapol. tetrapol is to tetra like DMR to NXDN (not much in common). this is most probably encrypted tetra, some services additionally use end-to-end encryption
henrygb
Hi. Following the tutorial in RTL-SDR, using Ubuntu 14.04 LTS 32bit. USB Nooelec receiver. Installing GNU radio 3.6 take a lot hours maybe low speed internet. Now try to run software and this error
user@ubuntu:~/osmo-tetra-sq5bpf/src$ ./receiver1 1
Traceback (most recent call last):
File "demod/python/simdemod2.py", line 18, in <module>
import osmosdr
ImportError: No module named osmosdr
Any idea to fix it?
kermit_t_f
After trying to install gnuradio in Kali 32 bit and Lubuntu, I gave Debian 7.7 a try. It took really a while, but it works with my rtlsdr and delivers clear audio. Tuning in the top block gui isn''t as easy as in the original osmotetra, but it works and that's the main point for me.
Thanks for this great work!
