Tetra supported ?
ludek-brno
Brno-CZ
So when finally support for Tetra TMO / DMO protocol with X36 and SDS100 / 200 scanners ?
KE4ZNR
Radio Geek
Until there is enough demand you won't see it in any commercial scanner.
Add in the fact that there are so few TETRA systems on the air here in the US I would not
hold your breath.
Marshall KE4ZNR
DeepBlue
Columbus, Ohio
Firmware was released as Beta for the AOR DV-1 a few weeks back to test with, for Tetra. FYI. Read their firmware page for details.
S.
KE4ZNR
Radio Geek
S.
Considering that this is the Uniden products forum I don't know what info on an AOR Receiver (not scanner) has to do with the original question asked.
Marshall KE4ZNR
DeepBlue
Columbus, Ohio
"Until there is enough demand you won't see it in any commercial scanner." ....
is why I made the comment. Yes, it is not a scanner but it is a commercially made and available radio receiver (which scans - not trunk tracks) that will receive Tetra.
S.
EricCottrell
Boston, Ma
Hello,
The op is in Česká Republika, where there are likely more TETRA systems. I have seen comments elsewhere in regards to TETRA support for the SDS100E and the response received from Uniden Japan was reportedly they are working on it.
I recently went on a trip through NJ and wanted to load the beta firmware onto my DV-1. The DV-1 did not recognize it as firmware and I wonder if it only works on unblocked receivers. I suspect that if Uniden does come out with TETRA support, it may only be on the SDS100E (European Model).
73 Eric
Ubbe
Stockholm, Sweden
Tetra pretty much replaces P25 in europe so remove that if needed and also let the japanese think tank consider adding MPT1327 that's still used in many places in the rest of the world.
/Ubbe
DeepBlue
Columbus, Ohio
Load both DV1 and DV2 files on your card. The receiver will only see the correct version. I have been loading both versions on the SD cards since I have had mine (over a year now) and it only sees the one it can use. Not sure why all the confusion on versions to load?
S
ludek-brno
Brno-CZ
AOR Digital Scanners do not display TG / CC / RID.
I'm a spoiled Uniden Scannerist with US models (no E versions).
Tetra's support is the future and the next appels for Uniden Team
As a paid update for X36 / SDS scanners, it would be amazing
Ludek
hardsuit
Vrigo Super Cluster, Milky Way Galaxy, Sagatarious
Right now there is not Enough TETRA use in America National frequencies to justify inclusion in Whistler or Uniden scanners.
However Professional Wideband Communication Receivers like AOR and ICOM will have TETRA reception capability.
if just come down to Price, Licensing and how often the Digital Mode is used, to justify Inclusion.
Its the same reason why American Scanners don't include dPMR and VHF CB Radio frequencies (AKA VHF FRS).
the Bands are simply not used here.
